Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 06-28-2004, 06:11 PM
Ralph Fickett Ralph Fickett is offline
1984 528e a/c not starting
I have a 528e that will not allow the a/c compressor to start when i push in the ac control on the dash. The inside cooling fan starts but the compressor will not activate it clutch.
If i jump it out the compressor runs fine and it blows good cold air.
We check the a/c charge and it looks good.
Can anyone tell me if there are other safties that i maybe over looking?
Old 07-02-2004, 08:26 PM
jeffreyb4me jeffreyb4me is offline
Re: 1984 528e a/c not starting
okay, ready? power comes from the A/C button through the Evaporator Temp. Regulator [inside the car on the L/S of the 'heater box'], [5 wire connector]. Power in is the green/yellow wire. Power out of it to the HIgh Press. Switch is the black......black/white wire. From the High Press. Switch on the rec/dryer it goes to the Compressor Clutch. Check for B+ @ the High Pr. Swt. 1st with the system on. IF 0 volts, go to the Evap. Temp Reg. checking power in then power out. there's a core temp sensor involved but the usual failure is the contacts of the Evap. Temp. Reg...have fun ! !
Old 07-02-2004, 11:09 PM
csieminski csieminski is offline
Everyone using this forum ought to make regular payments to you in exchange for your professional background and expertise!!
Old 07-02-2004, 11:35 PM
YES ! please make your checks payable to my
"he wants to take a world tour fund"
thanks csieminski.......................................j b.
Old 07-03-2004, 10:16 AM
I'll send mine tomorrow--$4.00--that's all I can afford right now!
Old 07-03-2004, 10:43 AM
Europe, here I come !.....................................jb.
Old 07-04-2004, 12:28 AM
If you could get $4 from every AF member, then...that would be different! Seriously, your advice is worth a lot of $$$, even if only through saving other BMW enthusiasts a ton of money.
