Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-28-2004, 04:37 PM
j_luis_nnz j_luis_nnz is offline
Question Ho to test Tail Light Sensor
I have a light showing up on the dashboard about the tail lights on my '91 Camry Wag Any ideas on how to test the Tail Light Sensor?
were is it located?.Is there any way to do a Bypass? I'm new to the Toyota Arena so please be patient with me.
Thanks for your time Jose.
Old 06-28-2004, 07:48 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Ho to test Tail Light Sensor
Easiest way to "bypass" it, is just to remove the bulb...I know plenty of people who have done it...just be sure that none of your bulbs are blown...and check your wiring in the rear to make sure nothing's shorting out, once it's been confirmed that there is no problem, remove the bulb.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 06-29-2004, 12:06 PM
Joe W Joe W is offline
Don't forget to check the center-mounted brake light.This is often overlooked.Different replacement lights will also trigger this due to different resistance between the sides.
Old 06-30-2004, 03:34 PM
thanks for the help I'll look in to it and I'll tell you guys my findings.
From The sunny Baja Peninsula Jose.
Old 07-01-2004, 11:03 AM
calvic calvic is offline
It is located in the trunk, generally behind the left side wall of the trunk. Easiest way to check it is to unplug the two connector to it, open the yellow plastic inclosure and inspect the PC board for broken solder traces. This is generally the problem. Be aware if the tail light wiring harness is shorting out around trunk hinge area you need to fix that problem first.
JJ
1988 Camry LE
4 cyl Auto
335,731
1994 Volvo 940 Turbo
1992 Dodge Cummins Turbo Diesel
2006 Mustang GT
