Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 06-28-2004, 04:08 PM
JumpJet19 JumpJet19 is offline
Tune up thoughts...
I am looking for suggestions on tuning up my 1984 944. I did all the belts, dist, rotor, wires. It has only 54k on it, so it's still running like a champ. Beautiful car. I'm just looking for some hints, maybe better spark plugs, better ignition, something to pep it up???
Thanks...
Jim
Old 06-28-2004, 08:23 PM
aeronautica86's Avatar
aeronautica86 aeronautica86 is offline
Send a message via AIM to aeronautica86
Re: Tune up thoughts...
Well, if it's "running like a champ", I would suggest not doing a thing! And if you want to pep it up, spark plugs and ignition are not the places to start from (or change at all if you already have). For more HP you could try exhaust, headers, K&N, MAF....or selling it and buying a turbo.
The best things in life are fast...
Old 06-28-2004, 11:40 PM
930guy 930guy is offline
Well, actually the best place to start is the basics. Make sure the ignition system, fuel and air filters are up to snuff before you go adding after market goodies.
Old 06-29-2004, 11:53 AM
83-944 83-944 is offline
Describe pep.
More pep could mean better throttle response. A MAF kit would be the quickest way to your goal. Possibly a lightened flywheel and so on.
More pep could also mean more power. Exhaust, headers, cat bypass. That's about it for engine bolt-ons. After that you go inside.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 06-29-2004, 11:55 AM
I'd hate to plug this in, but have you tried a DE or AutoX? It's god awful expensive to upgrade a car but it can be much cheaper to upgrade the driver.
You wouldn't believe how much go your car really has.
Old 06-29-2004, 12:37 PM
^^^ I agree with above
Old 06-29-2004, 04:48 PM
Well, more pep as in it likes to lag a little on initial acceleration rather than just open up. And when I let go of the accelerator with the clutch disengaged the motor drops below 1k sounding like it's about to stall, but then comes right back above 1k and sits perfect, all within a second. And were those chips you were mentioning? What weight oil is prefered for the summer months?
Thanks for the help!
Jimmy
Old 06-29-2004, 10:28 PM
Jimmy
Not chips, driver improvement! DE= Driver Education, AutoX= Autocrossing.
Both of which teach you about the real limits of your car and yourself in a "safe" manner.
Usually a 15-50 or 20-50 weight oil for summer driving.
Also, for your shudder fix.
http://www.frwilk.com/early944/misc//shudder.htm
Old 07-03-2004, 01:55 PM
It sounds like what you want is better throttle response....in which case, as stated above an MAF kit will be the best option, but will also be $$$....so maybe try a chip and throttle response cam...
Old 07-03-2004, 03:05 PM
Ben944 Ben944 is offline
Send a message via AIM to Ben944
or you can always skip the $30 or so for the throttle response cam and make your own like i did. it looks stock, until you look harder.
Old 07-06-2004, 10:19 PM
Question
All right, I'll bite and act stupid: describe to me what a throttle response cam is, please...
Thanks!
Old 07-07-2004, 08:10 AM
dont worry, i had to do some research too when i first heard about it. the throttle cam goes on top of the throttle body and the accelerator cable hooks up to it. the stock one has a big arm coming off it so you have to push the gas pedal down alot to get it to rev. you can buy throttle cams that are a little smaller and dont have the arm, so when you push the pedal the same amount, it revs higher. basically it makes it seem like your throttle response is better.
