Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 06-28-2004, 02:41 PM
OUTER EDGE OUTER EDGE is offline
95 Riv A/c Problem
My 95 Buick Riviera's Got A Puddle Behind Passenger Seat Since Using A/c How Do I Stop This? Where Do I Get New Carpet?
Old 06-30-2004, 11:51 AM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
Re: 95 Riv A/c Problem
you need a new heater core try looking for a carpet on e-bay are goo to the dealer
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 07-01-2004, 12:49 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: 95 Riv A/c Problem
He has a puddle behind the rear seat and he has a bad heatercore
check for holes in your floor boards sor something.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-01-2004, 01:12 PM
Thats What I Said ?????
69" BUICK RIVIERA
1999 OLD ALERO
Old 07-01-2004, 02:24 PM
Hypsi87's Avatar
Sorry I did not word that right, If the heater core was bad, then why would there be a puddle behind the passenger seat?, Besides when you have the climate contorl set to cold, their is a vacume accuated valve that block flow to the heater core.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 07-01-2004, 03:04 PM
Is My Pproblem A Heater Core? If So What Kind Of Repair Bill Am I Looking At?
I Found The Part To Be $215.00
Old 07-01-2004, 03:56 PM
Hypsi87's Avatar
he may be right, but let me look in my manuall and see exactly where everything is on that car.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 07-02-2004, 08:01 AM
Thanks Any Help Appreciated
Old 07-02-2004, 06:57 PM
I had a car that did the same thing it was the heater core but not too sure on yours Morderator
might be right about the hole in the floor bord have you check that OUTER EDGE?
69" BUICK RIVIERA
1999 OLD ALERO
Old 07-03-2004, 04:42 PM
Titan4 Titan4 is offline
My heater core just went bad too and I just had the dealer replace it. It cost me $457.33 ($186.00 - Labor; $271.33 - Parts). My actual bill was $959.00 though because I had them do several other things that needed to be done.
http://ucfpics.com/95Riv.htm
Old 07-19-2004, 06:02 PM
HarleyMoose HarleyMoose is offline
Thumbs down 95 A/c Problem
Another thing we have experienced that causes a puddle on the rear flow behind the pasenger seat is related to a drainage problem. If the drain is plugged the overflow can run down the center console to the rear floor, passenger side. If you find clear water, and no anti-freeze, this is likely the problem. We had the problem in the Summer of 2000
Old 07-19-2004, 06:03 PM
See New Reply
Old 08-08-2004, 09:44 PM
96Rivman 96Rivman is offline
I had the same problem on my 96. I pulled all of the carpet out and had my son run a hose over the entire car and could not find a leak. Then I noticed that when the air conditioning was on the water that was leaking out of the drain hole on the evaporator housing was running right back into the car. I ran a bead of silicone around the drain tube and it took care of my problem. I'll bet I had at least 1.5 gal of water on the passenger side of the car. If you pull the carpet back you should be able to see were it runs back into the car on the passenger side up on the firewall. Good luck
Old 08-21-2004, 10:22 AM
Intellgntandblonde Intellgntandblonde is offline
Send a message via Yahoo to Intellgntandblonde
You have a ac drain plug on rt front that may be clogged. Before replacing heater core, I would make sure that there is no blockage causing ac drain to back up.
Old 02-22-2005, 09:35 AM
tigerlillie63 tigerlillie63 is offline
I have the exact same problem with my 95 Riv. I've been to many web sites pertaining to Buick Rivieras and in every forum I've visited, there were several folks who have this water soaking the carpet problem. Mine showed up in the carpet in the rear passenger side. Also under the seat where the battery sits, there was about 2 inches of water. No smell to the water, so I KNOW it's a condensation situation. It only happens after extended use of the air conditioner. I don't know why anyone would think it's the heater core, because if it were, the fluid would smell like antifreeze. I haven't had the money to get mine into the shop, but now after reading your post, seems I can probably get my neighbor to seal it for me. Glad I visited here. GM should have put a recall on this because of the fact that so many people are experiencing the same problem. Thanx for your post.
