Old 06-28-2004, 01:39 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
thermostats
how does changing your thermostat add hp? and how much hp? and will you gain any more hp with a 180 thermo instead of a 160?
Old 06-28-2004, 01:45 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: thermostats
perhaps a few ponies, in light that a cooler running engine will transferr less heat to the intake charge before combustion, however it will negatively impact warm up time and emissions, so its more of a trade off, id say run a 180-190 thermostat if you want to drop the temp downa bit. 160 is a bit extream for a street car in my opinion.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-28-2004, 04:19 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: thermostats
Yea... I think that changing a thermostat is like changing pullies... some things are better left at factory specifications, and changing one thing will adversly affect many others, like a butterfly effect (excuse the corny metaphor). Plus, if you have a 98+ they dropped the stat from 195 to 180 anyway.
Old 06-28-2004, 05:14 PM
DiabloGT's Avatar
Banned
Re: thermostats
if i put in the 180 will anything hurt the engine or no?
Old 06-28-2004, 05:25 PM
89IROC&RS's Avatar
Re: thermostats
i dont think it will hurt anything.
Old 06-28-2004, 05:31 PM
DiabloGT's Avatar
Banned
Re: thermostats
how much hp would probably be gained w/ a 180 thermo?
Old 06-28-2004, 07:12 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: thermostats
i doubt any will be gained....
Old 06-29-2004, 12:48 AM
Re: thermostats
yea... me too, it is one of those mods that really only shows gain on a very very heavily modified car... on a side note, I dropped from 195 to 180 in my 96 RS... had to change back in the Winter, it wouldn't get hot enough and I had barely any heat inside.
Old 06-29-2004, 11:55 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Re: thermostats
The 15 degree coolant temp drop wont affect incoming air temps enough to give you any noticeable power.. If you really want a cooler running engine, I suggest the Hypertech Thermomaster chip w/ a hypertech or similar 160 degree thermostat..
It'l adjust your closed and open loop operation temps to keep your engine running properly and taking a/f info from the proper sensors
But as 89Iroc said.. Definatly gonna affect warm up time, no heat in the winter, and it might affect your emissions..
1991 Camaro Z28
Old 06-29-2004, 11:57 AM
DaMoNe6969's Avatar
Re: thermostats
oh, do a throttlebody coolant bypass to keep the coolant away from your incoming air all together
1991 Camaro Z28
Old 06-29-2004, 12:11 PM
gurrzt gurrzt is offline
Re: thermostats
The line of thinking is the cooler the temperature is that the engine is operating the less detonation, and more horsepower can be obtained.
This however is true to a point. Unless you are blown or turboed, I would not run a 160 thermostat, it is just too cool of a temperature for the LS1 engines. I am running a 180F in my 2001.
HOWEVER, IF YOU DO NOT CHANGE THE FAN ON/OFF SETTINGS IN THE PCM, OR GET A MANUAL FAN ACTIVATION SWITCH, IT IS ALL IN VAIN ANYWAY. With stock on/off settings the engine will heat up to stock settings anyway.
Old 06-29-2004, 12:49 PM
DiabloGT's Avatar
Banned
Re: thermostats
what if i get a hypertech kit thing and a 160 thermostat?
Old 06-29-2004, 12:50 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
I Went from a 180 to a 160 in my GN, I did not gain a damn thing, but my theroy is that something cooler will last longer than something that is hot. Heat kills all.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 06-29-2004, 01:12 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: thermostats
my thoughts exactly. not to mention the fact that the engine HAS to be more efficient somehow, its physics...
*Better power-to-weight ratio than a C6 corvette*
Old 06-29-2004, 06:33 PM
91HO305TPI 91HO305TPI is offline
Re: thermostats
AC delco makes a 170 degree t-stat that should give good heat in winter and will keep cars from over heating in summer espically the 3rd gens
