Old 06-28-2004, 01:25 PM
g00eY's Avatar
g00eY g00eY is offline
paint not sticking
i was painting my side mirrors two days ago and the paint wont stay on. when i brush on the yellow you can still see the gray underneath. what can i do?
Old 06-28-2004, 01:28 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: paint not sticking
Did you use primer?
Old 06-28-2004, 01:29 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Well for one thing a primer would help. Second you should spray the side mirrors. Brush marks are bad, especially for the exterior.
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 06-28-2004, 01:32 PM
g00eY's Avatar
well i really dont want to buy a whole can of spray just for two small parts off of a tree. im still working on my CLK D2 from Tamiya. i guess ill try to prime it wen i get some primer. ive never painted the outside of a car before.
Old 06-28-2004, 02:04 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Re: paint not sticking
Being cheap will end up costing you more in the end. Modeling is not an inexpensive hobby. Just buy a couple cans of Tamiya Fine Surface primer, and a can of Tamiya yellow.
-Mike
Old 06-28-2004, 02:38 PM
proosen's Avatar
proosen proosen is offline
...and as you are painting yellow it's not easier. Yellow is one of thoose hard to cover paints, if you use Tamiya acrylics it shouldn't be a problem to brush paint the mirrors as you could put on a rather thick layer without any problem. This paint shrinks very much so you wan't loose any detail that way. With enamels and brushpaint you will have to go for many thin layers in order to cover the plastic and get an even finish.
Good luck!
Niclas
Old 06-28-2004, 02:44 PM
g00eY's Avatar
ok.. time to get all that yellow paint off and start over
