Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-28-2004, 11:56 AM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
motor is in the car, now the question...
ok, the motor is in. when i went to start it it just turned over and didnt start. i checked fuel pump. it pumps so i have fuel. checked spark no spark. started diggin around and came out with some facts. i have an msd external coil. the coil has a positive connectoin and a negative connection. the problem comes in over here, im reading positive on both! i know the distributor is fine because i jest went to my friends house yesterday and put my distrubutor on his gsr and it woked fine. any help would be appreciated
Old 06-29-2004, 07:48 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
check to see if you're getting any spark at the wire. if not and you know the fuel is straight it's more then likely the coil. my coil went out after a tuneup once took me like 2 days to figure out it was the coil.
Old 06-30-2004, 01:38 AM
integralover's Avatar
integralover integralover is offline
that's very true. my coil went and gave me no warning at all. turned over fine, but no spark. found one at a junk yard for $30. yea, i went the really cheap way.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 06-30-2004, 12:39 PM
~ls/vtec~'s Avatar
Re: motor is in the car, now the question...
im using an external coil. the master blaster 2 from msd. i took the distributor and the coil to my frinds house and tried it on his integra and it worked fine. as i mentioned i have 2 positive wires going to the coil. one has to be positive and one negative.
Old 06-30-2004, 12:46 PM
~ls/vtec~'s Avatar
the engine is a 94 gsr its in a 98 civic. theres something wrong with the wiring
