Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-28-2004, 12:53 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
lsvtec in the car, and here comes the question..
ok, the motor is in. when i went to start it it just turned over and didnt start. i checked fuel pump. it pumps so i have fuel. checked spark no spark. started diggin around and came out with some facts. i have an msd external coil. the coil has a positive connectoin and a negative connection. the problem comes in over here, im reading positive on both! i know the distributor is fine because i jest went to my friends house yesterday and put my distrubutor on his gsr and it woked fine. any help would be appreciated
Old 06-29-2004, 01:38 AM
RPMtuner RPMtuner is offline
Re: lsvtec in the car, and here comes the question..
it sounds like your msd has a short, is it new? power is not going through the coil but just streaght to ground
Old 06-30-2004, 01:42 PM
~ls/vtec~'s Avatar
its new but im just using a master blaster external coil from msd. i know it has to do something with the wiring because the motor is a 94 gsr in a 98 civic.
Old 06-30-2004, 02:04 PM
Re: Re: lsvtec in the car, and here comes the question..
you should be able to bench test that coil by giving power and when you take the power away it should colapse and spark to ground
Old 06-30-2004, 09:16 PM
~ls/vtec~'s Avatar
i got some progress. when i turn the key to start the car my spark dissappears. when i throw a wire on the starter and try it that way my spark is there. but i have no compression at all because i had a valve job done so some of my valves were open im currently adjusting that, so ill fire it up before midnight cuz i have to go somewhere right now for a couple of hours
