Old 06-28-2004, 06:10 AM
gtmud gtmud is offline
96' Silverado won't start
I have a 96 Silverado, that won't start. I have fuel,fire, air. Fuel pressure is within spec. Double checked timing, dead on. Engine will crank-over, but won't run. Suspect something that might control injectors, not sure what though. HELP!
Old 06-28-2004, 08:32 AM
Jeremy-WI Jeremy-WI is offline
Re: 96' Silverado won't start
How are you checking timing? A bad CKP, or an obstruction on the CKP could cause a no start, but I don't think you'd have spark either then, double check the injector harness to make sure it makes good contact. What is the fuel pressure? Does the pressure drop when the fuel pump quits? Does the pressure drop while cranking the engine?
Old 06-28-2004, 09:21 AM
The timing was checked at the dealership along with the fuel pressure. According to them it was good.
Old 07-01-2004, 09:55 AM
Jeremy,
Found the problem to be a faulty distributor cap, go figure, it cost about $200.00, but I suppose that was mostly diagnostic charges.KISS!
Old 07-04-2004, 09:33 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
ouch, could have gotton a accel performance cap for under 50 bucks at www.truckperformance.com and rotor like 15ish i dunno
