Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 06-28-2004, 04:01 AM
fiero_1986 fiero_1986 is offline
steering colum is lose
on my 1986 fiero my steering colunm is lose so to start my car i have to wiggle it and it dosent stay still when im tryin to turn a corner and its annoying if u know how to fix it let me know
Old 06-28-2004, 02:10 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: steering colum is lose
Do you have tilt steering? It sounds like the bushings are worn out where the wheel tilts or the latch is broken. Best fix is to just swap a column from a junked fiero - for info on parts check out www.kickhill.com/fiero.html
You can replace the internal parts but most of them are dealer only and taking apart the wheel and electronics to get at the tilt is a pain in the ass...
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 06-28-2004, 10:35 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
most times the problem is as simple as tightening up 4 small bolts behind the turn signal switch. not all that bad if you have the tools. remove wheel remove screws holding turn signal switch in and pull up out of the way. once you do this you can see 3 of the 4 small bolts or screws 7mm if i remember right just tighten those 3 and you should get it tight enough to be useable . if anything is broken you will have to get a replacement collum. good luck
Old 06-29-2004, 09:19 PM
steering
ya i have the tilt wheel but thats not's broke it just wiggles from side to side just a little though
