Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-28-2004, 02:47 AM
metalhead00 metalhead00 is offline
Question 96 explorer fuel tank prob
My gas gauge doesnt work good. It says full when its half empty. But my question is how can you check the floater in the gas tank. How do you remove the tank. also what are the sizes of your fuel tanks.
Old 06-28-2004, 07:48 PM
Opera House Opera House is offline
Re: 96 explorer fuel tank prob
Hmmmmmm.....Full. The sender is 15 ohms empty and 170 ohms full. Does it read full all the time or at one point it drops down. Could be a bad connection going to the tank. Unplug the tank electrical connector and plug it back in to clean the contact. If it reads correctlu below a certain level then the ceramic resistor plate is cracked. I'm told this is only available with a new pump assembly. Dropping the tank is a lot of work. Straps may be frozen by now. Use a floor jack to support the tank shield.
Old 06-28-2004, 11:10 PM
the gauge does go down but gets stuck at different levels, and ill drop lower and get stuck. then when i fill the tank back up it starts all over again i have a feelin its the floater in the tank
