Which Gear ?
I run a 1993 GLX 2.3l dual port fi at my local 1/2 mile asphalt circle track, it is a stock class no mods allowed. My problem is in the turns if I shift to 2nd gear when I get into a turn my rev limiter kicks in, if I stay in 3rd I lose my RPMs and get a crappy exit. I would like some suggestions on what ring and pinion I should be using. Thanks
ring and pinion doesn't count as a mod? interesting. well, if you go up in ratio (bigger number), you will turn more rpms in 2nd gear, which should give you a cleaner exit. you'll lose a little top speed tho.
somebody correct me if i'm wrong, it's almost 5 in the morning and i can't sleep edit: having reread the origional post, i realize i'm an idiot. yet i should still be right cuz you'd still turn higher rpms in 3rd, solving the problem.
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
Re: Which Gear ?
Have you thought about having a custom chip burned to remove the rev-limiter?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Re: Which Gear ?
you said its a stock class no mods so what can you do first we can work from there.
Re: Re: Which Gear ?
My diff cover tag : 8 45 75 3f18 : S2900 |
if i'm reading that right you have a 3.18 gear... maybe step up to a 3.53?
Re: Which Gear ?
Re: Which Gear ?
id go with 4 tens i drove a 90 with everything stock but fourten gears and it grabed me by the nuts
