| Off-Topic Talk about anything other than cars. |
Dash lights and SRS problem
today i was installing a new cd deck into the car. we pulled all the wires out and connected them via same color connection. well we couldnt get the constant to work properly. long story short when we did connect the cd player it turned on the whole dash panel as if the car lights were on. after pulling all the wiring out of the cd player unhooking everything the dash lights wont turn on and the SRS light is stuck on. all the gauges work properly by the way. thanks for any help!
aaron |
Re: Dash lights and SRS problem
well do this.. disconnect your battery and reconnect....
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE ![]() ^^^ hehehe 2000 Ford F-250 boostin' 30 psi 1997 Lexus ES 300 2000 Mazda 626 1999 Mazda Protege 1991 Geo Storm boostin' 10 psi 1998 Eclipse GSX boostin' 16 psi 1991 Oldsmobile Cutlas Calais |
already tried that-no good. thanks though
did you check all the fuses? You might have blown something...
![]() Check out my site After Night Groove Team Site RS-T Build Up Site http://www.angelfire.com/pro2/rst |
you said that you have all the wires disconnected hanging in the dash opening? sound like a hot wire is shorting somewhere
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
everything is hooked up now. all fuses are good. any other ideas?
make sure all the fuses are there, my srs light was on and i checked my fuses and one was actually missing. check that one more time, its the reverse lights fuse thats connected to the srs system.
