Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-27-2004, 09:50 PM
rjeanes rjeanes is offline
Holding Crankshaft Pulley
Am getting ready to change the timing belt on my 97 Camry 2.2L. Anybody have any good tricks for holding the damper pulley while loosening/tightening the bolt holding it on?
Any other techniques or suggestions also appreciated.
Thanks in advance.
Ray
Old 06-27-2004, 09:55 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Holding Crankshaft Pulley
Wedge a large screwdriver against a converter bolt.
Old 06-28-2004, 09:46 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
$50 electric impact wrench worked for me.
Was able to hold the harmonic dampener by hand, and the crankshaft bolt spun right out without moving the pulley (handy for keeping the timing marks aligned).
Might be a good idea to get a harmonic dampener puller also. When I removed mine, I found the last mechanic had chipped the back of the pulley and dented the oil pan preesumably from prying with a screwdriver (I think yours will take 8mm bolts for the puller)
