Old 06-27-2004, 09:15 PM
TELUSMobilityGuy TELUSMobilityGuy is offline
99 Accord: brake light switch?
OK.. I've concluded that I need a new brake light switch.
Shift lock would not release, had to use key to release manually. Checked brake lights, both do not illuminate when brake pedal pressed. Checked bulbs, OK. Checked fuse, OK. Got pissed off, so came inside and searched online, found a few that had same problem, took back to Honda, turns out was brake light switch.
Anyways:
- anyone have any idea how much this part costs?
- can I fix it myself? If not, how much is this going to cost me?
TMG
Old 06-27-2004, 11:14 PM
HONDA_99 HONDA_99 is offline
Re: 99 Accord: brake light switch?
switch cost about US$30 at dealer.
if you were in USA you could order it from this place, but unfortunetly they don't ship to Canada.
switch is #4 on picture and in list.
http://www.hondaautomotiveparts.com/...catcgry5=PEDAL
Old 06-27-2004, 11:37 PM
Thanks.
Think the switch is likely the source of my problem?
Old 06-28-2004, 06:47 AM
AccordCodger AccordCodger is offline
Quite possibly. But it might only be the plastic "button" that's pressed into the brake pedal, and that operates the switch.
Cheap & easy to replace (if you don't mind lying upside down under the dash).
Old 06-28-2004, 10:40 AM
Plastic?! why why why would plastic be used in place like that.
anyways, will check it out, thanks.
Old 06-28-2004, 11:32 AM
There really isn't much strain on the "button" - just the tension of the return spring on the brake pedal.
Old 06-28-2004, 02:44 PM
Tension on return string is sufficient to press the button. Ordered a new switch, will plug that in to see if it resolves my problem.
Old 07-19-2004, 04:44 PM
snelson218 snelson218 is offline
Wink so helpful! how to install?
First of all, thanks for posting this, it prevented me taking my 86 accord in to the shop when the brake light wouldn't turn off. I found the broken plastic piece on the floor in the car and have ordered and picked up a new one (Pad, Pedal Stopper). Now, where does it go? I don't know anything about cars, but figure that I can do it instead of paying someone to fix it. Any help would be appreciated! Thanks!
-Sarah
