Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-26-2002, 11:30 AM
thecone137 thecone137 is offline
Send a message via AIM to thecone137
necessary gauges
what are some necessary gauges to add when installing a turbo application???
Old 01-26-2002, 12:56 PM
94civic's Avatar
94civic 94civic is offline
boost gauge, oil temp and af ratio
Old 01-26-2002, 06:46 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
exhaust gas temperature gauge is good to have also
Old 01-28-2002, 02:52 PM
pvang31019 pvang31019 is offline
egt, boost, oil pressure
Old 01-29-2002, 12:32 AM
Someguy Someguy is offline
Send a message via AIM to Someguy
EGT is very nice because you don't want to cut the car off while the turbo is still hot. A turbo timing is a very nice extra. If you're not familier with them, baiscally when you park your car you can take the key out of the ignition, get out, lock the door, turn on the alarm and walk away. The turbo timer will keep the engine idling until the turbo has cooled down then shut off the engine.
I would also have a A/F ratio guage just because I'm a little paranoid and things not can, do, go very, very, wrong if you lean out with FI for whatever reason.
Boost. Hey its cool to watch. Spend that much money on a turbo you deserve a cool gadget.
Oil pressure is good. Oil and coolant tempatures are also nice to keep an eye on things especially on a hot day with a stock radiator/no oil cooler.
