Old 06-27-2004, 05:33 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
exhaust issue
for one i was wondering if the exhaust heat shield is even needed or can i jsut take it off. and 2 i was wondering if 421 exhaust headers are better then stock 91 civic dx hatch back headers
Old 06-27-2004, 05:42 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: exhaust issue
Heat shield is there to keep the heat from spreading farther into the engine bay. If you remove it you more than likely wont see a differnce. Yes you will see some power out of a 421 header. Honestly I would save up and do an engine swap. I know you dont have much income sence your 16 but with a summer job you could probably save enough to get an integra motor from a junk yard for a few hundred bucks (localy around 500 for motor and tranny, but I dont know where your located at). If you do put on a header make sure you put a good exhaust system on because it would be kinda pointless to put a good flowing header on a shitty flowing exhaust.
Old 06-27-2004, 09:35 PM
Re: exhaust issue
beleive me if i could have a integra motor i would but right now my motor is under waranty or so ive been told and well i dont have the tools to swap a motor out
Old 06-28-2004, 08:56 AM
Forunn Daberator
Re: exhaust issue
that header will more than likely void that waranty
