Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 06-27-2004, 03:05 PM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
Finally decided the first major modification for my Tiburon...but I need help
I figured it out as I was driving home today. Suspension mods!!!
Something around lowering springs and stiffer springs etc, but I'm not sure where to start. I'm looking for quality parts for lowering ,camber and other suspension stuff that I probably I have know clue about. I'm also looking for a reasonable price too, so I can put it on my "wishlist"
HELP!!!
Thanks
-ColeIketani
PS: I'm going to go suspension, (good to have "perfect" handling before you go fast) tires and brakes, (before I go fast, I'd like to know that I could stop) then engine mods..... (so then I can go fast knowing I can brake and stop)
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 06-27-2004, 10:49 PM
curbie curbie is offline
Banned
Send a message via MSN to curbie Send a message via Yahoo to curbie
Eibach has some pretty good lowering springs, struts & sway bars. Eibach.com I think is the website. Just my two cents
Old 06-28-2004, 04:53 AM
Adam_Hunsicker's Avatar
Adam_Hunsicker Adam_Hunsicker is offline
Re: Finally decided the first major modification for my Tiburon...but I need help
I bought the ones on the Hyundai Performance website:
http://www.shop.hyundaiperformance.c...i=EBH_4220.140
They're Eibach 1.1" lowering springs and I had them compressed to stiffen them up a bit and give me a total drop of 1.6". Overall I think they're pretty good springs but if you've got the $1100+ dollars to drop on coil-overs go ahead... personally I have no use for them. Also, I recommend you get some strut bars, you can find them here:
http://www.sharkracing.com/sus/hyund...-aluminum.html - aluminum
or
http://www.sharkracing.com/sus/hyund...rbonfiber.html - carbon fiber
I went with the aluminum because they were cheaper. Between the drop and the bars I've noticed QUITE a difference in the turns.... I can guarantee that I'll wash out far before I flip. LOL
Adam
Black '03 Tib, 2.0, Auto
Old 06-28-2004, 04:59 AM
p.s. - total cost of those springs and the aluminum sway bars is only $400.00 + S&H
Adam
Old 06-28-2004, 12:35 PM
bingo, that's what I'm looking for. Thanks Adam
Old 06-30-2004, 10:18 AM
tibby01 tibby01 is offline
if i were you, and i was REALLY serious about handling, i would save up and get a complete coilover package.
Old 06-30-2004, 06:38 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
coil overs! word
frt/rr strut bars
aint sway bar
Old 06-30-2004, 06:42 PM
ok so what would that cost? the whole coilover set....
Old 06-30-2004, 06:45 PM
Tib Guy
it depends... theres different degrees of how you want your car to feel/ what youre using your car for...
id go for street/ sport... and if you really want to look into it.. performance packages.....
strut bars... not that expensive at all...
sometimes you can find a deal on ft and rr together...
aint sway bars are liek the hundreds.... 1-2 hundred
Old 06-30-2004, 08:06 PM
so could you explain how the sway bar works?
and some people who make them?
Old 06-30-2004, 09:24 PM
sway bars reduce body roll. you connect a big straight bar to the frame of the car. then with bushings(so it can rotate) you attach arms to the front suspension.
when you go into a left turn(lets say) and weight is transferred to the right side, the suspension compresses on that side. that causes the arm to go up, and creates torsion in the bar. the torsion created then compresses the other side, causing the car to stay flatter on the road.
to much sway bar, and you lose the suspension independence of the left to the right side. as in, when you hit a bump on the right side it will affect the left side. no sway bar, and you could flip.
i know eibach makes some sway bars for my RD, but im not sure about your car.
Old 07-01-2004, 12:44 AM
03tibv6 03tibv6 is offline
which would be better for strut bars...shark racing or mussa
Old 07-01-2004, 04:09 PM
Tib Guy
thats all preference
