Old 06-27-2004, 01:29 PM
punkskate0303 punkskate0303 is offline
95 or 98?
which eclipse is alittle better couse i have an option to get one of thoes 2
Old 06-27-2004, 01:50 PM
my97blackgst my97blackgst is offline
Re: 95 or 98?
I would go with the 98, Because it's newer, Newer exterior, What's the miles? Has the maintenice been done properly at the recomened intervals? But what model are you looking at? RS, GS, GS-T, GSX? and if you don't me asking how much are they wanting?
Cheers
Ben
1997 Mitsubishi Eclipse GS-T, Auto, A few small upgrades
Old 06-27-2004, 01:52 PM
Chavez408's Avatar
Chavez408 Chavez408 is offline
Send a message via AIM to Chavez408 Send a message via Yahoo to Chavez408
The mods are really going to get up in your ass if you keep askign questions like these. I dont know witch one is "better" but I belive the eclipse '95 was the only one to have a EPROM in their ECUs, but in the other hand..IMO the '98 eclipse looks alot better.
1990
Inagural model year of the DSM.
Pop-up headlights.
Some high-end models had wheel covers.
All ECUs had EPROMs.
Front brakes change during the model year.
1.8L models have the 4G37 engine, all others have the 4G63 engine.
1991
ECU changes mean that 1991+ ECUs don't operate the 1990 tachometer correctly.
Most ECUs had EPROMs.
First model year with ABS available. ABS not available with limited-slip differential (LSD).
All high-end models had alloy or mesh wheels.
First year of the Galant VR-4 - 2000 sold in the American market.
1992
Non-popup headlights introduced on all models.
The first AWD Lasers were introduced.
Few (or no) ECUs have EPROMs.
ABS now available with LSD.
The engine changes from the 6-bolt version to the 7-bolt version in April.
Second and final year of the Galant VR-4 - 1000 sold in the American market.
The last year of the Dodge 2000GTX.
1993
"Big brake" 2-piston front calipers become standard on turbo models.
7-bolt engines are now standard.
No ECUs have EPROMs.
Diamond-Star Motors ceases to exist.
1994
All cars built to California emissions standards - there are no "Federal" cars.
The last year of the 1G car and the 1.8L NT models.
The last year of the Plymouth Laser.
1995
The inagural year of the 2G DSM.
Significant changes to the engine, body, and electronics.
New transmissions.
All ECUs have EPROMs.
Non-turbo models are based on the Chrysler 420A engine instead of the Mitsubishi 4G63 engine.
OBD-II becomes standard on DSMs, along with two oxygen sensors.
Mitsubishi begins using some substandard crankshafts, leading to crank walk on some 2G cars.
1996
The first year of the convertible Spyder.
The Mitsubishi 4G64 engine is offered, in the Spyder models only.
ECUs stop having EPROMs.
1997
Additional body changes from the 1995/1996 models.
Minor changes to the ECU code.
1998
After many years, Mitsubishi finally issues a recall on the AWD DSM transfer case.
1999
The last year of the 2G car, and of the 4G63/AWD DSM platform.
The last year of the Eagle Talon. Chrysler drops the Eagle marque.
- http://members.shaw.ca/costall/1000Q/
- Its Micheal Jackson! and his black again!!! YAY!!!!!!
LandoAWD - My rolemodel!! why? because his a bad ass! beache..! and he will kick ur A$$!!
Originally Posted by Delerious93integra
and if DSM's are so great.. then why doesn't everyone own one
^^^ WOW!!! ^^^
Old 06-27-2004, 02:09 PM
Re: Re: 95 or 98?
Cheers
Ben
I dont know what it is it just says its an eclipse i dont know is its a rs gs gs-t or gsx but there both 4,500$
Old 06-27-2004, 02:15 PM
Chavez408's Avatar
Re: 95 or 98?
then how are we suppose to help you?? if you dont even know what models your talking about or saw...
^^^ WOW!!! ^^^
Old 06-27-2004, 02:44 PM
Re: Re: 95 or 98?
ill send you a link here look at ithttp://www.autotrader.com/fyc/vdp.jsp?car_id=165361128&dealer_id=&car_year=1998& make=MIT&distance=300&max_price=&model=ECLIP&advcd _on=n&end_year=1999&min_price=&first_record=451&ce rtified=n&address=92236&search_type=used&advanced= n&start_year=1995&=&color=&cardist=64
Old 06-27-2004, 03:13 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Re: 95 or 98?
http://www.autotrader.com/fyc/vdp.js...or=&cardist=82
try those
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 06-27-2004, 03:26 PM
Re: 95 or 98?
Looking at those here is what I would suggest. First off the 95 is not an eclipse but and eagle talon tsi (same car different names) the 95 will have 210hp turbocharged vs 140hp n/a, GET THE 95 you will not regret it. Things to look out for, Timing Belt should be changed at 60k intervals if I am not mistaken. Be sure all the fluids have been changed when supposed to. Make sure your clutch has a nice smooth take up and no jerking. Without being there I am going to have to say the 95, more power blah blah..but insurance will be higher as well then the 98. It will require nothing less than 91 octane where as the 98 will run on 87 due to the fact that it is n/a. My two cents anyway...good luck.
Cheers
Ben
Old 06-27-2004, 04:22 PM
What about this one?
http://www.autotrader.com/fyc/vdp.js...95&=&color=&ca
Old 06-27-2004, 04:34 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: 95 or 98?
^^ seems like a good deal.. if there is nothing wrong.
For Sale 98 Eclipse GS, 5 spd
Old 06-27-2004, 05:28 PM
So do you guys think i should go for that black 95 or this 98? or this othe 95?
http://www.autotrader.com/fyc/vdp.js...or=&cardist=64
http://www.autotrader.com/fyc/vdp.js...or=&cardist=83
Old 06-28-2004, 04:56 PM
Old 06-28-2004, 04:59 PM
Chavez408's Avatar
Re: 95 or 98?
have you even called the owners to see if their even still selling the car?
^^^ WOW!!! ^^^
Old 06-28-2004, 07:37 PM
RomainDeaMarchi's Avatar
RomainDeaMarchi RomainDeaMarchi is offline
Re: 95 or 98?
Gs Turbo Awd?
Old 06-28-2004, 08:53 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 95 or 98?
good list chavez! is that in the faq if it isnt it should be send it to eclipserst or somebody and get him to put it in
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
