Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-27-2004, 12:45 PM
WalterK103 WalterK103 is offline
1987 Camry overheating
Hi, all,
First, I've gotta admit I'm an automotive idiot. However, I figure if I could learn how to build a computer from the internet, I can learn how to do simple car repairs with enough help from people who have the patience to walk me through terms and techniques I don't really understand (LOL, it's great to be educated).
I have an '87 Camry wagon that SEEMS to overheat very rapidly, at least the temp gauge tends to hit the red zone within about a mile. Driving maybe five miles, it will fluctuate between too hot and normal. In the dead of summer, I turned on the heater, with it directed to the floor, and cold air came out the upper vents! The radiator is not boiling over, and I don't see any leaks in the hoses or radiator itself. When the car is running, the fans near the radiator are sometimes on, sometimes off.
Just guessing, I think the problem could be the thermostat. Possible? As a first step, I'm thinking of making a stab at replacing it. Question 1: Where is it located????? If I can find it and take it off, I'll take it to a parts store and get another one, along with any other stuff I might need. Please help. Any tips about what I might run into would be appreciated!
Old 06-27-2004, 01:43 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: 1987 Camry overheating
Originally Posted by WalterK103
Hi, all,
welll im sorry i can't help you with where it is.. etc.. but yes its the thermostat.. i had a mazda mpv.. it help overheating for some reason.. after we changed that.. it was ok but sorry i can't help more... and just to let ya know its not hard to build a pc =P
Old 06-27-2004, 01:50 PM
Computers are simple, cars are hard, .
Old 06-27-2004, 10:06 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
When the car is cold, open the radiator cap and see if the level of coolant is all the way to the top. Then put the cap back on twisting it until it is in the same orientation as it was before you removed it.
Check your coolant in the plastic reservoir. Make sure it is at the full mark when hot. If not, add some 50:50 water:antifreeze until the reservoir stays full.
If this doesn't solve the problem, the next most likely thing is the thermostat. Buy a Haynes repair manual for your car and it will show you most everything you need to know.
Old 06-28-2004, 09:34 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Do yourself a favor and get the Toyota thermostat. Yes, there's a difference is quality.
On the Generation 3, there's also a "jiggle valve" than should be aligned with a mark (raised line) on the water inlet.
Old 06-28-2004, 01:56 PM
bertmaster2000 bertmaster2000 is offline
1.) buy Chilton's repair manual, not Haynes.
2.) drain antifreeze from radiator using the drain cock located on the rear, center, bottom of the radiator.
follow the lower radiator hose from the radiator to the engine. Where the hose connects to the engine there is a "water neck" that houses the thermostat. two metric nuts (11mm?) hold the water neck onto the engine, remove them and the water neck will come right off. remove the old thermostat from the water neck, replace with new thermostat AND GASKET making sure to orient the new thermostat according to the "to radiator" stamped on one side of the new thermostat. reverse procedure to install. add 50:50 antifreeze til radiator is full.
