Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 06-27-2004, 09:15 AM
racingrl1980 racingrl1980 is offline
Send a message via Yahoo to racingrl1980
Question EGR valve
Hello! I am new here, and own a '97 Avenger and the check engine light comes on, and then goes off, then comes back on. The idle is WAY low and I took it to Auto Zone to have that sensor checker thing determine what the problem was. It detected that my EGR valve is not responding. The guy there said for me to clean the EGR valve, and somewhat showed me where it was. I need help locating it and DETAILED instructions on how to clean it! LOL ALSO, could the EGR valve be causing my idle to be so low?
Drive It Like You Stole It!
Old 09-14-2004, 09:30 AM
edicius edicius is offline
Send a message via AIM to edicius
Re: EGR valve
Seems that I am having the same problem at the moment... :-/ I'd be interested in the reply you get, would be helpful
Old 10-30-2004, 09:34 AM
JackDaniels386 JackDaniels386 is offline
Re: EGR valve
what type engine?
Old 02-23-2005, 03:58 PM
nakissa nakissa is offline
Unhappy
Ya I have the same thing wrong erg vavle and yes it will make it idle low i think there should be a recall on this part. I have a Avenger v6 2.5 liter
Old 03-01-2005, 12:04 AM
Televisor Televisor is offline
I own a 1999 Avenger V6 and my car had the same problem. At first my idle started acting up then it got worse to when it would die out coming to a stop. I replaced my EGR valve and problem went away.
Old 03-04-2005, 06:52 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: EGR valve
there should be NO recall. this is a comon problem and it happens on all cars. yes it will make it idle low. you can clean this part in about an hour with out to much trouble and it will work good, i know cause i have an avenger and i did it. i did it on my mustang too. the egr valve has a round black peice on the top of it. its right in the front of the engine bay, shouldnt be to hard to find, go to the ASEC website and they have a ton of posts about it. just buy some carburator cleaner for less than $3 and get some q-tips and clean out all the holes in the thing. i believe it bolts right onto the side of the engine
