Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-27-2004, 09:50 AM
tazinus tazinus is offline
Unhappy horn doesn't work
We have an 95 explorer and the horn doesn't work . Is there anyone out there that can help us. We have check all the fuses and relay and they are good.
Old 06-27-2004, 02:49 PM
michelq michelq is offline
Re: horn doesn't work
does the air bag light flashing on and off when you turn the ignition switch on ?
Old 06-27-2004, 06:22 PM
the air bags light comes on when starting,stays on for a few seconds,then goes off.(we can't even find the horn under the hood) do you know where it is located.
Old 06-28-2004, 07:41 AM
look in under hood fuse block for fuse and horn relay
swap relays to know if relay is bad
Old 06-28-2004, 11:57 AM
The fuse and relay are good. But the horn still doesn't work.
Old 07-19-2004, 05:18 PM
DonnyH DonnyH is offline
Question Re: Re: horn doesn't work
Are you sure the relay is good? We had the same problem -- and the relay clicked when the horn was pushed. However -- we replaced the relay anyway on the suggestion of a mechanic and it fixed the problem...
Old 07-27-2004, 08:42 PM
robert J robert J is offline
I had the same problem. I found that there were 2 horns under the left front and appeared to be hooked in series. One wire was off disabling both horns.Could be the problem but I have a 99.
