Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-27-2004, 07:41 AM
iceman2 iceman2 is offline
Unhappy Stripped bolt
Help! I accidentally broke one of the two bolts that holds the thermostat housing on the engine, should I drill it completely out or try to extract it?
Old 06-30-2004, 09:03 AM
dhspring dhspring is offline
Re: Stripped bolt
I would definitely try to extract it, drill a small hole in the center of the bolt and use and EZ-out to reverse it out, otherwise if you drill it out your problem is going to get worse, make sure to center punch before you drill the hole or your bit may drift off center, this should be a relatively easy extraction.
Old 06-30-2004, 09:49 AM
Re: Stripped bolt
Thanks, yeah I tried that with a burnish type extractor, broke it off too, would not drill out because it's such hard steel and lodged into aluminum, drilled two new holes on each side of broken bolt, unfortunately one went right into coolant, JB Welded everything, no leaks, however, tepmerature fluctuates about 50 degrees.
