Old 06-27-2004, 03:09 AM
mchengsp33 mchengsp33 is offline
Send a message via AIM to mchengsp33
putty question
hi just wondering what kind of epoxy putty i should by for making body kits? quick type or smooth surface type? thanks
Old 06-27-2004, 10:36 AM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
do a search, much info on this topic has already been brought up and discussed.
quickie version: quick type will dry harder faster, smooth type will not have a completely hard plastic feel (you can leave indents with your nail), but working with it is easier.
Ed-
Old 06-27-2004, 04:03 PM
Re: putty question
hi, thanks!
Old 06-27-2004, 04:47 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: putty question
IMO, quick type.
-Mike
Old 06-27-2004, 06:02 PM
Re: Re: putty question
hi, thanks for the replies! actually i was using basic type of putty from tamiya to do some joints, however, when i try to sand the putty it was soft and the joints broke..so i looked at the FAQ and found out i should use the epoxy putty..is the quick type going to be really hard to sand down once it became hard? if i use the smooth surface type will it be not strong enough for me to sand the joints? thanks
Old 06-27-2004, 07:26 PM
mike@af's Avatar
Re: putty question
The quick type is hard, it took me a little getting used to. But the stuff is great, I cant say anything bad about it. The putty sands great with 100 Grit sand paper.
-Mike
Old 06-27-2004, 07:45 PM
IImportSupra's Avatar
IImportSupra IImportSupra is offline
Send a message via AIM to IImportSupra
Re: putty question
Quick Type all the way, I havent done anywork with 1/24 scales, but heres an example of what it looks like.
BTW this is a Crummy Modifier. I need to stay away from those.. :<
