Old 06-27-2004, 03:29 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Replacing seals in brake master cylinder
How easy is it to replace the seals in the master cylinder. My brakes get really soft after driving in the heat for a while. Feels a lot like a seal is going bad. I've never worked with the master cylinder before.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 06-27-2004, 03:41 AM
jimmy[the]gent's Avatar
jimmy[the]gent jimmy[the]gent is offline
before blaming the master cylinder check to see if it could be a bad wheel cylinder maybe its leaking brake fluid [assuming ur back brakes are drumbrakes] and check too see if on ur front brakes if the caliper is leaking could just be air in the lines because of that or maybe it could be ur brake lines i would check all those things before assuming the master cylinder is the culprit
or maybe some how air got in the line from lack of brake fluid and all u have to do is bleed the brakes
good luck with that
Old 06-27-2004, 03:55 AM
4G4D Store's Avatar
Whoops, forgot to mention that I've put all new brake pads and rotors on the front, and completely flushed the whole system with all new brake fluid and bleed the lines. Still getting soft. Also, there aren't any leaks, I've checked the level of the brake fluid and it hasn't changed in weeks.
Old 06-27-2004, 09:56 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Replacing seals in brake master cylinder
Just get a remanfactured MC, they are only like $40.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-27-2004, 10:13 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Its not really that hard to do, but I would suggest jsut going with a remaned unit like mentioned above, alot easyer.
Old 06-29-2004, 12:51 AM
4G4D Store's Avatar
Is there a good place online to get a remanufatured mastercylinder? Also, if I'm buying the whole thing might as well upgrade to the Integra MS, which years/models will fit the 4Dr EX model. Thanks
Old 06-29-2004, 05:44 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Yeah I Would Just Buy A New One I Had A Similar Problem And I Just Went To The Local Auto Parts And Baught A New One.
°Sä®GëNTö69°
B20B POWERED '91CRX SI
