Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-27-2004, 12:46 AM
zzhangz zzhangz is offline
How to reset the change oil indicator
Hi,
It's Buick Century 2003. I lost the owner's manual.
Is there anyone can tell me how to reset the change oil indicator?
I usually change oil in other Auto Service but not Buick dealer.
Thanks.
Old 06-27-2004, 02:17 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: How to reset the change oil indicator
How to Reset the CHANGE OIL SOON
Light
The GM Oil Life SystemTM calculates when to
change
your engine oil and filter based on vehicle use. Anytime
your oil is changed, reset the system so it can
calculate when the next oil
change is required. If a
situation occurs where you change your oil prior to a
CHANGE OIL SOON light being turned on, reset
the system.
After changing the engine oil, reset the system by
performing the following steps:
1. With the engine off, turn the ignition key to
RUN.
2. Fully push and release the accelerator pedal slowly
tnree times within five seconds.
If the CHANGE OIL SOON light flashes, the
system is resetting.
3. Turn the key to OFF, then start the vehicle. The oil
life will change to 100 percent.
If the CHANGE OIL SOON light comes back on,
the system has not reset. Repeat the procedure
This may help also, an online owners manual.
Old 06-27-2004, 11:49 AM
Thank you so much!
I had reseted it!
