Old 06-26-2004, 10:09 PM
Allamand Allamand is offline
Question on the T&C 2004
I just picked up a 2004 T&C and looking for some after market products such as the rear mud flaps and the covers for the floor when the seats are removed.
I found a site that has them, one states these are 2000-2005, the other says 2000-2003. Was there a body change from 2003 to 2004 model year? I haven't really been following the Dodge/Chrysler mini-van for a while as I had a 96 and 01 Windstar the past 7 years.
I like this van so far, though I can say I never had any problems with either of the Wind stars, with 98k on the 96 and 62K on the 01. I sure hope the T&C is as good to me as they were. Though after reading about these Trannys, I wonder a bit.... But them new Freestars just looked so "Cheap" on the inside... even the Limited with the leather seats, the back bench was vinyl!
Old 06-27-2004, 09:21 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
My understanding is that 2001-2004 body styles are the same.
I've purchased mud flaps out of the Mopar Accessories catalog for my '04, and the parts are listed as 2001-2004. Also on the transmission side, I became a little worried about it after reading all the horror stories on this forum and other forums, but then I figured with the 7yr,70,000mile warranty, I'm not too concerned. This is my first venture into Chrysler products (of approx 25+ vehicles), the deciding factor being styling and value compared to everyone else's products.
Good Luck
Mike
Old 06-27-2004, 04:37 PM
Re: Question on the T&C 2004
Thanks for the info Mike. I need to order them rear Mud flaps as well. I really like the warranty that the ofer too, at least for 70K were all set if something does come
Old 06-28-2004, 06:09 PM
vipergg vipergg is offline
If you want good mudflaps for the get the mopar moulded flaps at your dealer , they are a little expensive at $35-40 dollars . But these fit right into existing screw holes and you have to drill nothing and can put them on in about 10 minutes . You will need a 45 degree offset phillips head screw driver if you want to put them on without pulling the tires .If you have the offset its a easy install . Don't get the big flat ones you have to drill with those I believe and the moulded ones look a lot nicer because fit right to the mold of the bumper . Got them for my 2004 T&C .
Old 06-28-2004, 07:44 PM
Thanks Vipergg, I found these part#82206703 for $32 online. These are the ones, correct?
https://www.1stchryslerparts.com/pro...oducts_id/1433
I was wondering if they make factory ones that are larger for the front?
Also, anyone have one of these in there van?
https://www.1stchryslerparts.com/pro...oducts_id/1419
It is pricey and was wondering how well it works and if it would work for the 04's as it is listed for 01-03 years
Old 06-29-2004, 06:16 AM
Re: Re: Question on the T&C 2004
I purchased the molded flaps for the rear, I paid the list price thru my local stealer/dealer,$38.00 I think. Chrysler/Mopar parts didn't have a larger flap for the front, and I don't like the after-market parts, so I'll live with the factory small flaps that came as part of the body mouldings.
I have the Cargo stand that came as part of an option package item that came with the Van. They're nice, but they do have weight limits to them; 20 lbs when standing up, and 100lbs when folded down. It is easily removable if you want to carry heavier loads.(Two large hand/thumb screws) The stand has 3 fold-up compartments that keep items from rolling around. Each compartment holds a bag about the size of a standard brown grocery bag with a little extra space in each.
Old 06-29-2004, 04:31 PM
those look a little different but the description sounds right . There is no design on them like the picture that is shown .
