Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-26-2004, 08:47 PM
RustyG RustyG is offline
Send a message via AIM to RustyG
Unhappy Newbie in need of help
The other day I went to the store, shut the car off which was running perfectly. I came out, tried to start the car and it was a no go. It would start but ran badly for about 2 to 3 seconds then stalled. It acted as if it were running on 2 cylinders. Come to find out after we got it in the garage, cylinders 1 and 4 are firing, 2 and 3 are not. Changed the coil and still the same thing. It is a 1993 Eclipse GS with a JDM engine 4g63. I have already checked plugs and plug wires. All are good. I can not find anything disconnected anywhere. Any idea's?
Thanks
Rus
Old 06-26-2004, 09:12 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
Could be a few things, timing belt jumped, ECU problems are 2 big ones to check.
Old 06-26-2004, 09:38 PM
Re: Newbie in need of help
Timing is ok, checked that.
How do I check the ECU?
Old 06-26-2004, 11:42 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
is the check engin lights on? flashing?
DSM geek
Old 06-27-2004, 03:28 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
check compression!
Old 06-27-2004, 07:21 AM
Re: Re: Newbie in need of help
Originally Posted by EclipseRST
check compression!
I have spark on #1 and 4....No spark on 2 and 3
Plugs are good, wires are good...one the side of the coil for plugs 2 and 3 is dead...
What i did was this, took all plugs out left them plugged in and cranked it, only 1 and 4 were sparking..to check plugs and wires i plugged 2 and 3 into the 1-4 side and they sparked.
Camsensor? possibly?
Old 06-27-2004, 01:19 PM
sounds like the ECU has aproblem.
Old 06-27-2004, 01:20 PM
EclipseRST's Avatar
Banned
your ignition coil could be bad... other than that your ECU but the CAS wouldnt only make 2 cylinders fire and no the others!
Old 06-27-2004, 03:01 PM
I changed the coil, same thing. Took the camsensor apart and noticed a very very tiny crack. Would that cause this malfunction?
Old 06-27-2004, 05:06 PM
EclipseRST's Avatar
Banned
it could... better replace it!
Old 07-03-2004, 04:25 PM
Some tell ,e it wouldnt matter cuz the if the sensor is firing 1and 4 it should still fire the other
I have no clue, this has everyone stumped. Anyplace else i can check to see if anyone knows?
Old 07-04-2004, 09:51 AM
i find it odd that their is no check engien light..
DSM geek
Old 07-04-2004, 10:39 AM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
i find it odd too b/c i don't think 1g 4g63 n/t has CAS at all...
Old 08-19-2012, 06:42 PM
vr4 SITTNSIDEWAYZ vr4 SITTNSIDEWAYZ is offline
i have this problem well my car only sparking of 2 and 3 .ive got 2 computers to choose from ive resently put stock standard ecu because my other one is chipped and tune ive changed the both coil packs with going car still no spark ? to 2 cylinders but now ive got spark in 2 and 3 and no spark in 1 and 4 its weird please help i need my car going again
Old 08-19-2012, 06:43 PM
my engine is a 4g63t with a very large turbo in a 1988 vr4 galant manuel needs spark
Closed Thread
