Old 06-26-2004, 08:45 PM
86birdboy 86birdboy is offline
86 Firebird headlights won't go down
I have a 86 Firebird and my headlights work but they wont go down. Any ideals what the problem is?
Old 06-28-2004, 12:09 PM
H1ghWayMan H1ghWayMan is offline
Re: 86 Firebird headlights won't go down
The motors are known to fail when old but they may just be too stiff for the power or it may be a fuse. Thry turning them manually and seeing if they are fairly easy toturn or not.
Check the fuses.
Everyone has value. Personally I serve as a bad example!
Old 06-29-2004, 12:44 PM
89birdowner 89birdowner is offline
light switch
although i am not sure, i think it is your headlight switch. get it replaced(switch is like $10 or so). i had same problem in my 89 but never replaced switch because i traded my car in. i was emailed by someone who had the problem and he replaced switch and it worked. this is what happened on my car, when you press the off button the lights turn off but the lights dont go down. but they work fine turning on and going up.so try that and see where you get. good luck.
Old 06-30-2004, 12:08 AM
koeb$ koeb$ is offline
Send a message via AIM to koeb$
im going to agree wit h1gwyman, your motors are prolly shot n need to b replaced, look in a junkyard n save a good bit of money, or go to yearone.com or paddockparts.com n find them
84 TA- 350 bored
dynomaax shorty headers
custom 3" exhaust
electric exhaust cut out
holley 600 cfm carb
340+HP
cam?
97 jetta
white 15" bbs wheels
2 JL 12W3's and 2 JL 500/1 amps (for sale)
Old 07-05-2004, 06:36 PM
korrrray korrrray is offline
im sure its the motors, but pop the hood and there is a black circle nub and you twist that thing for about 3 minutes and you can put them down manually, hey you have an american car, what else do you expect? lol
Old 07-06-2004, 01:24 AM
tomminajar's Avatar
tomminajar tomminajar is offline
There is about 15 different reasons why - You would have to find a manual to help or go read this-
http://www.michiganfieroclub.org/headlight.htm
Its for fiero's but It's about the same...
