Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-26-2004, 06:43 PM
Chevy_girl00's Avatar
Chevy_girl00 Chevy_girl00 is offline
Send a message via MSN to Chevy_girl00
Question New rims, new tires....=new brakes???
If i get 20's and new tires do i need to put new brakes on my 2000 Chevy Silverado??? If so, what are some good kinds to get?? Also, will it screw with anything else?? Suspension?? Shocks?? Springs?? Anything??
Old 06-28-2004, 05:36 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: New rims, new tires....=new brakes???
everything should be fine, braking will be marginally reduced by the heavier wheel/rim combo but not enough to require new brakes before service is normally due.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 06-28-2004, 10:24 PM
monty120 monty120 is offline
Well, Depending Onyour Tock Rims Size If The 20's Are A Few Inches Larger Than Stock, Your Stock Brakes Won't Stop You, You'll Need To Upgrade Them.
Old 06-29-2004, 11:22 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
It all depends on the weight of the wheel and tire combination. If you increase the weight too much, it will increase the load on the brake system and you should look at better brake pads/rotors.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
