Old 06-26-2004, 06:07 PM
Ziggy1 Ziggy1 is offline
Cool Fuel Pressure Regulator
Help:
Tring to locate the fuel pressure regulator on my truck, 1996 chevy z71 k1500?
Old 06-27-2004, 07:32 AM
Jeremy-WI Jeremy-WI is offline
Re: Fuel Pressure Regulator
Its in the upper intake manifold. It is mounted to the passenger side of the injector assembly
Old 06-27-2004, 10:47 AM
Thanks for the info I had no clue. Learning as I go. Tell me this how and what needs to come off to get to it?
Old 06-27-2004, 03:00 PM
Throttle cables should be removed and a lot of sensors get unplugged so you can move the harness out of the way. The coil bracket needs to be loosened if not removed. I know I just saw a post with a better description, I'll post a link if I see it again
Old 06-28-2004, 04:40 AM
Thanks again for all your help!
Old 06-28-2004, 07:12 AM
One more thing, once all the bolts and studs are out of the upper intake manifold, be gentle while lifting it off because the injector assembly will likely want to stick a bit and too much pressure may break something. You might want to get the upper intake gasket kit as the gasket on the injector assembly will probably be stretched out
Old 06-28-2004, 10:20 AM
Thanks I am just about to pull the top of the intake off. Started to rain so I had to stop. A lot to do for such a little part.
Old 06-28-2004, 11:13 AM
Is there an easy way to unhook the two gas lines in the back of the motor or is there another place to unhook them?
Old 06-28-2004, 12:48 PM
I took my torch to an open end wrench to make it work
Old 06-28-2004, 04:15 PM
Got it and putting things back together again. Thanks again for all the help you gave me it helpped out a lot. Looks like she will be taking me to work in the AM. Thanks again Ziggy1
