Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-26-2004, 03:38 PM
theyman theyman is offline
Exclamation front disc dreaks make a rubing sound
the break on the right is making a rubing sounds but the left is ok when you apply them they dont sounds the same any sugestions
Old 06-26-2004, 06:26 PM
chaser29's Avatar
chaser29 chaser29 is offline
Re: front disc dreaks make a rubing sound
Have the same issue with my front left side. It is pissing me off. I just had new rotors and brakes put on and the fact they are rubbing knowing this fact pisses me off to no end.
I tried cleaning them, putting W grease on the outer portions, but every time I apply some pressure, the sqeeking makes me mad.
If you find out then let me know. Glad soemone else asked this question, before I did.
http://members.cardomain.com/12311974
Old 06-26-2004, 06:36 PM
mybabiesmamasman mybabiesmamasman is offline
Send a message via Yahoo to mybabiesmamasman
I just started having that prob on my '86, but it started after I installed new pads. The rotors still looked great, so I didn't get 'em turned. Only thing I can think is that the caliper isn't moving the pads far enough when the brake isn't engaged, then again, its just a guess. My solution, turn the radio so loud that I worry about the topper flying off instead of the brakes squeaking.
Old 06-26-2004, 10:18 PM
yeah ill let you know and yea i think the calaber is the problem but im not sure yet im gunna work on it tuesday when i do the weel barings ill let yall know id turn the radio up but i just fin dit a lil emabising driving threw town with the noise after all im 16
Old 06-26-2004, 11:46 PM
chaser29's Avatar
Thanks, I am hoping it is something simple.
Old 06-27-2004, 09:32 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
take off pads & slide caliper back & forth to insure it moves free.look at piston to see if it has any rust or pitts around seal.also after reinstalling,compress piston in and step on brake pedal a couple of times to free it up even more.
Old 06-27-2004, 09:41 PM
ok thanks mudder
Old 06-28-2004, 04:10 PM
vanshoot vanshoot is offline
I had the same problem with my '87 Ranger. I changed and greased new calipers and never had the problem again.
Old 06-28-2004, 08:45 PM
chaser29's Avatar
Thanks mudder & Vanshoot, I will take a look, as well.
