Old 06-26-2004, 01:48 PM
ballgirl068 ballgirl068 is offline
Brake Job - Need Help
Can someone tell where I can find online information on changing the front brake pads on a 92 honda accord or should I just go buy a manual?
I need to do this job myself and want to make sure I don't mess it up.
I've don't brakes on chevy's and I'm not sure if it's close to being the same type of job.
I appreciate any info I can get.
Thanks!
Old 06-26-2004, 02:00 PM
BullShifter's Avatar
Re: Brake Job - Need Help
Changing front pads is easy.
Do the obvious, lift vehicle & remove tires
Remove 1 lower caliper bolt
Pivot caliper up
Remove old pads
Squeeze caliper piston in
install new pads lubed
Pivot caliper down
Re-install bolt
Time for the other side.
The brake rotors should get replaced or cut with new pads or they will not last very long. Don't forget to pump brakes before driving.
Old 06-26-2004, 03:32 PM
Thank You!!!
