Hi all.Newbie with questions.95 se
I have a 1995 grand prix se 4dr 3.1 and it started acting up this week.It will throw an ses light when driven on the highway at around 210 degrees .And will start to shudder at idle at stop lights to the point where it feels like it will stall.After it cools it runs fine until it gets around the 200-210. All the vac lines seem good. And how can I scan for codes..Thanks in advace for any info..
Re: Hi all.Newbie with questions.95 se
autozone does free code readings, from there they may or may not be able to tell you what to do but there are a number of places online to check for engine codes with a little more info like:
http://www.diagnosticdialog.com/LookupCode.asp |
Cool thanks for the info..I looked at all the parts today and all seems good .I will let yous know what I find ..
The symptons you are mentioning looks like the car is overheating. I got a 94 SE and when overheated will behave just like that and the dash/ECM reading would read less or around 210 when in reallity with the heat gun it was around 240. Check your low level coolant sensor, your coolant temp sensor and that the cooling system is not clogged. Of course get the codes but never would hurt to make sure that your cooling system is on tip top shape
Re: Re: Hi all.Newbie with questions.95 se
Ok this morning I changed out the TPS and the thermostat and it still has the problem. I can't find the fan relays .Only one fan turns on when the ac is on.Also now I noticed that when I give it a fair amount of gas the motor seems to cut out.It never did this before WTF. Does anyone know where the fan relays are for a 1995 grand prix se 4dr 3.1 ?? I will buy a new fuel filter to see if that fixes the cutting out problem .Thanks in advance for any info.. The car runs great till it reaches about 210 degrees then the ses light comes on and the car starts to sputter and wants to stall out . If I let it cool for a while it's fine till it reaches 210.And now it wont throw any codes at all...Help please....
Ok I changed CTS fuel filter checked all hoses and vac lines .Car is running better but still overheats .I have to turn on ac for fans to kick on .Once fans kick in it drops temp and runs fine .But I am still looking for the fan turn on switch or relays..Anyone...??
you could check your engine coolant temp sensor to see if its bad. if you can get at it all you need is an ohm meter and check the resistance between the two contacts:high resistance when the engine is cold:low resistance when the engine is at operating temp. if the resistance is high at opertating temp then the sensor is telling the pmc that the engine is cold when its actually hot. if the pcm thinks the engine is running cold then the pcm will advance the timing. this could explain the shuttering and stalling.
[size=5]
i was wondering if you ever found the problem tealse?
[size=5]
did you check the fans to see if they were still working? if not an easy way to check is with a pair of jumper wires, a couple of aligator clips and couple of t-pins, this is stuff you can pick up at radio shack. the wires from the fans(blk-negative)(lt blu &wht-positive) should be conected using the jumper wires to the battery. if the fans don't work than they're no good. the fan that might be giving you trouble would be the one with blk/wht wire.
[size=5]
[quote=AKWE-gt]did you check the fans to see if they were still working? if not an easy way to check is with a pair of jumper wires, a couple of aligator clips and couple of t-pins, this is stuff you can pick up at radio shack. the wires from the fans(blk-negative)(lt blu &wht-positive) should be conected using the jumper wires to the battery. if the fans don't work than they're no good. the fan that might be giving you trouble would be the one with blk/wht wire.[/QUOTE-------------------] Yes both fans are working but will not come on without ac being on---
the only thing that hasn't been changed would be the pcm this what a/c and the fans have in common, but you could change the rad cap and make sure the rad is good, run your finger along the vanes to see if they're not rotten.
[size=5]
