| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
425 cid wont stay in time
my 66 olds 425cid wont stay in time. i have a fairly oversized crane cam in it with the original distibutor setup (points/condenser) i used to get it up and running good at 10 degrees advanced. the problem is that when i get it dialed in and the distributor clamp tight and drive around the block the timing goes off again. any suggestions...maybe my points are shot?
Re: 425 cid wont stay in time
the rebuild was done a bout 20k ago. so the cam is worn in. its wierd its like the distributor turns itself out of time after the a few minutes. i had this problem in the past and usually after spending awhile and re-timing it it will settle in and be ok, but this year its being a real pain.
very possible...it is an old stock distributor. i never replaced the gear. i will have to check it out...thanks
