Old 06-25-2004, 03:49 PM
IBKitty's Avatar
IBKitty IBKitty is offline
Send a message via AIM to IBKitty
Same bulb?
Alright, just after having my new car for three days now I have found that my front passanger corner light is out, but the turn signal still works. So I am thinking, either it is one bulb that has multiple filaments and the running light part is out, or there are two bulbs in the corner? I am also assuming that the little screw on the outside is how I am going to be replacing this or these bulbs...? Help?
"I don't drive fast...I fly low."This is it!!! " 97 3000GT SL"
Old 06-25-2004, 07:56 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Well I jsut took my turn signal off today so I could get at the last bolt that holds on the headlight so I know there is only one bulb and yes that tiny screw is all that holds it in, unscrew the lil thingy and it should kind of swing out and you pull it forward to release these two metal clips that hold the back on, then you jsut twist the back of the bulb housing thingy and it will pop out and you can see if it's the filliment or not. hope this helps a bit, it's realy simple.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 06-25-2004, 09:17 PM
Thourun's Avatar
scratch that, I re read your post and realized that there is probably another light I missed but still take it off to see.
1995 3000GT VR-4
Old 06-25-2004, 11:25 PM
IBKitty's Avatar
Okay, yes there is only one bulb for the turn signal and running light. It is just a double filament bulb. Mini bulb, part number 3496 for $8.99 at Kragen Autoparts.
Old 06-25-2004, 11:49 PM
Thourun's Avatar
Heh cool so I assume it was one fillament that was busted from what you said, it's so nice to know that some chicks love cars as much (if not more) than I do.... sigh just wish mine did, her favorite car is the beatle, at least she likes mine a little thats good for her lol she thinks porsches are ugly and frog-ish .
1995 3000GT VR-4
Old 06-25-2004, 11:53 PM
IBKitty's Avatar
Frog-ish! Lol, that's funny, to think of it they do look frog-ish, I think that's what makes them a bit cute, as in girly car cute.
Old 06-26-2004, 12:55 AM
sLADe781 sLADe781 is offline
Re: Same bulb?
LOL They kinda do don't they. Hehe
