Old 06-25-2004, 02:42 PM
96camaro 96camaro is offline
COde: P1870 [Transmission Component Slipping].. Help!
2 weeks ago, my service engine lamp lit up and aftrer runnning the code, it reads " P1870 [Transmission Component Slipping]".
My mechnaic told me that something is wrong with the transmission based on the code, but needed to bring my car to a tranny expert (so he said) to have it diagnosed. Upon my request, he erased the code then.
Just yesaterday, this problem surfaced again... Any input on this problem will be appreciated.
Just hate to imagine the fact that I had to replace my tranny (may as well scrap it!)....
Old 06-26-2004, 10:19 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: COde: P1870 [Transmission Component Slipping].. Help!
your torque converter is going. the sensor is telling you that when the lockup clutch in the converter is supposed to have engaged, its still allowing slippage. meaning its worn out and needs replacement.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-26-2004, 10:57 PM
Torque converter going? Is that a serious issue if prolonged? How much am i looking at to replace it?
Old 06-26-2004, 11:08 PM
89IROC&RS's Avatar
not that much, i bought my converter on ebay for around 145 bucks, but for a new one from say B&M or something it might run you close to 300, maybe a bit more. to install it however requires removing the trans, which can be a few hours labor.
if you choose to let it slide, you will learn to live with your check engine light, higher trans temps, which may lead to premature trans failures, and reduced highway gas mileage. which will add up with current gas prices.
Old 06-26-2004, 11:17 PM
Hey, thanks for the advice!
Just to confirm.. I am looking at ebay for a torque converter now and its ending couple of days later. ARe you certain that its definitely the converter torque that cause this problem?
The reason I am asking this is that based on the code, my usual mechanic told me to bring it to a tranny specialist to have further diagnosis as my mechanic does not deal much with tranny issues. To save time, I will just get it off ebay and bring it to the tranny specialist to fix it..Thanks.
Old 06-26-2004, 11:25 PM
89IROC&RS's Avatar
well of course, this is an internet diagnosis, so only trust it so long as it makes sense, if you go and buy something i certainly dont guarantee it.
that being said, i am a chevrolet tech, specializing in corvettes electronics, and driveability problems. i am the tech assistant to the shop forman, and therefore act as an assistant shop forman helping all the other techs diagnose and correct their problems, i do not personally work on transmisions, however i do diagnose them. so my advice is baised off of training, experience, and knowledge of the onboard diagnostic equipment responceable for giving you that code. i am 90% sure that you have a slipping converter, however there is a possiblity that for whatever reason i am wrong, so take my advice with a grain of salt.
Old 06-26-2004, 11:37 PM
Cheers, 89IROC&RS!
Your words does make sense.. Anyway, I am just gonna pop down to the tranny guy and we see how..
Thanks for everything again!
Old 06-26-2004, 11:46 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Re: COde: P1870 [Transmission Component Slipping].. Help!
Best advice you've given Yet,
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-26-2004, 11:47 PM
FormulaLT1's Avatar
Fight the powwa!!!
J.k.
Old 06-27-2004, 08:03 AM
89IROC&RS's Avatar
Lmao!!!!!
Old 07-27-2004, 06:40 AM
biglagoon9 biglagoon9 is offline
Hello 89IROC&RS,
I'm having a a transmission problem of some sort with the P1870 error code. I have a 97 Suburban an posted on the chevy.Suburban forum. Brief description of probelm is after driving highway speeds and then comming to a stop, I get a very hard shift from 1 to 2, and 2 to third. If I shut the engine off (ie.e waiting for the light to turn green) the probelm goes away and does not return until highway speed driving aagain.
Any sugguestions?
Old 07-27-2004, 07:07 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
I could be wrong, but seeing as its the same code as 96camaro is having, it's probably about the same advice (torque converter). Just a guess tho.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 07-27-2004, 08:01 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
the new trannies can send the modulation times to the PCM and if the modulaton times are off (IE a clutch pack slipping) it will set that code as well. What I am trying to say is that I think this code covers everything from the torque converter to the clutch packs
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-27-2004, 06:12 PM
I am back!!
Got my camy to the tranny expert and had the valve body replaced with a brand new one. Got new gaskets/plates, and transmission oil as well.. Pretty reasonable.. Cost me about $270 (I think so).. Heard that it was about 350 & up for others.
And yeah, it all started with SES light on.. 1870 code diagnosed..Cleared it.. Popped up again... Cleared it... Popped up again after highway miles.. so far..its been a month... so far so good... Glad I did not take for a tranny rebuilt as some advised..
Old 07-28-2004, 09:16 PM
LiquidSmooth LiquidSmooth is offline
Send a message via AIM to LiquidSmooth
I just brought mine into the show also, it's a huge one downtown chicago, they had 34 bays and they all had cars on them, and the lot was full of cars to be worked on, he said he was gonna 'test drive' mine today and see what's wrong, but they won't even be able to look at anythign else till tomorrow, he said he wants 450 for the job, and that they make a kit for that specific problem. Does this sound about right?
