Old 06-25-2004, 08:49 AM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Cam Belt
How do i get this off? I am removing my head and this has to come off... any help?
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 06-25-2004, 11:01 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Cam Belt
its not the cam belt... its the timing belt and what you need to do is pull the tensioner that is located on the block right in front of the motor mount to loosen the belt... once that is off the timing belt will be able to slip right off the cam gears!
Old 06-25-2004, 11:07 AM
EclipseRST's Avatar
Banned
Re: Cam Belt
and why are you trying to do a head swap if you dont know how to get that off?? if i were you i would get someone that knows what they are doing before something gets fucked up!!! the head swap is not the easiest thing to do exspecially when you have to set timing (MAKE SURE YOU HAVE SOMEONE ELSE SET TIMING OR YOU WILL FUCK UP YOUR HEAD AGAIN!!!)
and stop posting a new thread everytime you have a question! its a waste of space.... since if you searched for it you would have found it!!! if you have a question from here on POST IT IN THIS THREAD... DO NOT... i repeat... DO NOT start another thread if you have a question! ask it in this thread!!!
Old 06-25-2004, 02:47 PM
98GSX's Avatar
Re: Cam Belt
ok... i guess all my posts will be here! thanks for being so nice... my dad will set the timing.. i am just taking it apart....i have never worked on DSMs only porsches, benzs, beemers; etc. mitsu is weird in their engineering... but i want a galant and throw a body kit on it so bad! >RANDOMNESS<
^^^ hehehe
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
Old 06-25-2004, 05:21 PM
98GSX's Avatar
Re: Cam Belt
I cant get the timing belt loose what the hell??? where is this tension pully??? any pics would be nice!!!
^^^ hehehe
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
Old 06-25-2004, 05:35 PM
98GSX's Avatar
Re: Cam Belt
how bout i answer my own question... http://www.vfaq.com/mods/timingbelt-2G.html
^^^ hehehe
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
Old 06-25-2004, 07:39 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Cam Belt
I was jsut going to suggest the vfaq on tbelt job. BE SURE you and your dad fully understand what is going on there.
This may be the simplest and most basic tip anyone could ever give you on this topic, but the most valuable. In order for the tension to be right, the gap between the hydraulic tensioner body and the arm that swings with the tensioner pulley on it, MUST be between .15 and .18 inches for the gap to be right. You can douche this whole project 15 times over and spend 3 months on it, as long as in the end that gap is .15 to .18 inches
Any yahoo can set up the marks, but be sure all FOUR of the cam gear marks are lined up, or damn colse to it (mine always end up a touch below the straight edge at 3 and 9 oclock (center)), and pay attention to the part about how to properly phase the rear balance shaft. Its possible to have that mark lined up to the pointer, but its still wrong.
Enjoy the reading, its a long one... Good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
