Go Back   Automotive Forums Car Chat > Racing > Formula-One
Old 06-25-2004, 06:39 AM
DynoDon DynoDon is offline
Explain venturi tunnel design
I know what they are and why they're used etc. I just can't find any solid info about their design.
Air that is sped up has less pressure, so the tunnel design speeds up the air, sucking the car to the ground..
Okay, is the tunnel 4 sided or is the ground the 4th side and side skirting helps maintain the seal?
I read about the inverted wing design implemented in a venturi tunnel. Then sometimes another tunnel seems to narrow side to side-speeding up the air that way.
Is there one basic design? Or do some tunnels simply have an inverted wing design while others narrow?
Point me towards an article with some good pictures or drawings please.
Old 06-26-2004, 10:33 PM
NSX's Avatar
NSX NSX is offline
Send a message via ICQ to NSX Send a message via AIM to NSX Send a message via MSN to NSX Send a message via Yahoo to NSX
Re: Explain venturi tunnel design
Have you tried searching it on google?
It yields some good results.
i.e. http://www.btinternet.com/~jhpart/bkwind5.htm
Old 06-27-2004, 08:09 AM
NSX your link is for wind tunnel design! I'm looking for info on the ground effects that F1 or Indy cars (can't remember which) use for example inside their side pods to add downforce to the car ..
Old 06-28-2004, 01:58 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I'm not an expert, but I'll attempt to explain it as I understand:
That's correct. Any time the air speeds up, there is an opportunity to create lift, or downforce, depending on the geometry.
The ground is the 4th side. This creates a tunnel that has a larger entrance and exit than the middle. Because the cross section of the tunnel is smaller than the entrance or exit, it speeds up the air velocity, lowering the static pressure. Since the top of the car is covered in normal velocity air, at a higher static pressure, there is a difference in the force on the top vs. the bottom of the car, and hence downforce (or lift) is generated on the car body.
Narrowing side to side is another way to increase the air velocity by decreasing the cross section in the tunnel. The inverted wing works just like an airplane wing, only - inverted. Any means of speeding up the air under a car can increase downforce. Most modern car designs use both shapes in the tunnels - narrowing side to side, and using an inverted curve shape in the top of the tunnel, the road being the bottom of the tunnel.
I'm sure there is no basic design, but any design used must be within the constraints of the car's design, physical laws and the racing rules (most of the time).
Hope this sheds some light on it for you.
p9o1r1sche
