Old 06-25-2004, 01:17 AM
nyteshade nyteshade is offline
help?
ok I like the body style of ford probe, nissan (200-300), dodge stealth, sunfire along those lines nothing too popular either...but i do want something around 200hp stock but under $14,000 any suggestions ?
Old 06-25-2004, 01:30 AM
Igovert500's Avatar
blue + red light magnet
Re: help?
First off welcome to AF,
now to answer your question will be a little more difficult. What are your goals, do you want a fast car, a sedan with enough space for your friends and moderate power, a gas-saver...will this be a daily driver, etc...
There is a car comparison part of this forum, also a car buying Q&A section. (I'm not sure if you are aware you posted in the part specifically for Mitsubishi 3000gt). From the cars you listed, it seems like a bit of variety. The stealth is essentially the same car as the 3000gt, and can come equipped with 161ish hp, 222ish hp, and a 320 twin turboed engine. The twin turbo stealth would be a drastically different car than a ford probe or pontiac sunfire. Also are you looking for a new or used car. My girlfriend had an 97 sunfire, it definantly didn't have 200hp, and wasn't all that fast, but it was only like 5 grand, which would leave you with quite a bit of cash for the ever-rising gas prices. Not knowing your exact interests or needs, I would suggest going to a few dealerships and testdriving multiple cars, to find what really suits your needs best. If you want more information, or advice on a specific car or cars, or have more specifics already in mind, don't hesitate to ask.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-25-2004, 02:24 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
May I reccomend a used 3000GT/stealth , or would that be plugging it? You can get yourself a 320 hp beast of a machine with all sorts of doo-dads like active areo, 4 wheele steering, 4wd, TCS, and many other goodies for around $14,000. or you could save alot of coin by opting for the 222 hp SL (like me) and not loose much except a bit of that power and the 4wd.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 06-25-2004, 08:17 AM
k i'll find the right section and I'll give you my goals hehe thanks for the info
