Old 06-24-2004, 10:23 PM
Slicer280's Avatar
Slicer280 Slicer280 is offline
(ABS) light on all the time
The truck runs fine but just yesterday running down the highway the amber ABS light ( the only one) came on and will always stay on. upon ignition start it comes on naturally then goes out for a second then comes back on and stays on....my pump is not running when I shut the truck off I have 54k miles....any ideas.
Old 06-27-2004, 08:13 AM
Slicer280's Avatar
Where's the love =)
Old 06-27-2004, 08:26 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: (ABS) light on all the time
The EBCM has seen a problem with the ABS system and has set a code...to find out where the problem lies, you will need to have the codes pulled to determine what circuit or componant is at fault.
A regular code reader will not work, you will need to use a bi-directional scan tool to access the EBCM.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 06-27-2004, 09:46 AM
Slicer280's Avatar
It just sucks...I just bought the truck 3 weeks ago. Now I have to spend the money to have a dealer tell me it's the ECBM...probably $100 to have me say stick it on the replacement cost, and then I do it myself sending it out to get it repaired for $100
Old 06-27-2004, 10:03 AM
GMMerlin's Avatar
I know stuff
Re: Re: (ABS) light on all the time
It may not be the EBCM that is bad....when there is a fault, there is a code set. reading the code and decifering the information helps to determine the root cause of the problem..this is called diagnosis.
If you spend a lttle time and money on some diagnosis, you could save big bucks on repairs (by not installing parts that are not the problem)
GM WCT
PM Me for details
Old 06-27-2004, 11:12 AM
Slicer280's Avatar
I know your right, but it just kills me that I just bought it and just from reading these forms the odds are stacked against me....seems all I read is the EBCM going bad around 60k on Silverado's...hehe guess what mine has 54k. Hmm
Old 06-27-2004, 11:17 PM
FCFFUZZYFACE FCFFUZZYFACE is offline
there were a lot of problems with the EBCM's on the 1999 model Silverados, but those problems were associated with a constantly running abs motor, have seen a few wheel speed sensors go bad on the later models but no EBCM's, you need to take it in and get the codes checked, there's about a $200 difference between an speed sensor and a EBCM, thats well worth the check out expense
FCFFUZZYFACE
Old 06-28-2004, 06:59 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Some parts stores like Pep Boys will read your codes for free. Call around, be sure to tell them you need to decode an ABS problem.
Old 06-28-2004, 03:43 PM
Slicer280's Avatar
Hey that's good to know......thanks guy's
