Old 06-24-2004, 10:59 PM
CR50HC CR50HC is offline
Can I use my DPFI Injection system on a D16a6 head?
Hi folks. My D15b2 is about worn out. I recently ran cross of really good deal on a rebuilt D16a6 head. Can I use my DPFI setup on the D16a6 head and bolt everything up to the D15B2 block? In simpler terms, can I just swap the D15b2 head with the D16a6 and keep using the DPFI until I save up enough money for the MPFI Conversion?
Next question, will I need a D16a6 Distributor or can I continue to use my D15B2 one? Will I need to buy a D16a6 timing belt? Will the PM5 work with this head? Will a D15b2 head gaket set work? I'm soo confused!!!
Troy
Old 06-24-2004, 11:58 PM
91civicDXdude's Avatar
Re: Can I use my DPFI Injection system on a D16a6 head?
replace your stock head with the d16a6 head and use *ALL* your other stuff. timing belt, distributor ETC, from the d15b2. it will botl right on with zero problems. the head is basically identical with a different cam.
Old 06-25-2004, 12:05 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
i canker like a sore
hehehehe
get it concor sounds like canker.
well its funny to me no its really not.......
Old 06-25-2004, 07:12 AM
It's good to know that everything will bolt right up. This will give me some time to save up enough money to do the MPFI swap. Eventually I may do a motor swap but, if I don't keep this one running in the mean time, I'll be walking....
Old 06-25-2004, 07:59 AM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
do you plan on putting rings and rod bearings in while you have head off? because if not then youll still have a wonr out engine just with a new head.
For You Are Crunchy And Taste Good With Ketchup!
Old 06-25-2004, 10:06 PM
Good question on the rod bearings and rings. I guess that would be a good idea to do. Is this an expensive undertaking?
