Old 06-24-2004, 09:45 PM
ral3ph ral3ph is offline
Unhappy radiator over heating
hi i just got a 97 z28 camaro and when stop at a light i've noticed the temp gauge starts to creep up to the hot side.I checked the radiator fans and they are not working any ideas on where to start checking why they don't come on.
thx for your help
Old 06-24-2004, 09:48 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: radiator over heating
first, how hot does it get? the fans dont come on till around 255* which is an eigth of a fraction over half way on the guage (about). second, id start with your fuses and relays. also, try turning on the a/c and see if the fans come on.
Old 06-24-2004, 10:00 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
and if that doesn't work, check the coolant temp sensor.
Old 06-24-2004, 10:07 PM
yeah thats the next step...
Old 06-24-2004, 10:09 PM
Genopsyde's Avatar
The President
we make such a great team dont we
hell yeah!!
Old 06-24-2004, 10:12 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
and if that dont work, check the fan plugs for
loose connections....that has happened to me
before.
Old 06-25-2004, 06:00 PM
Re: Re: radiator over heating
hi on the relays is there a way to check if they are bad?
thx
Old 06-25-2004, 07:30 PM
the best way that i can think of is to take one that you know works that has the same voltages and everything (like your headlight relay, or a/c relay) unplug the cooling relay and plug in the test relay. if it works than there ya go, if not than its prolly something else...
Old 06-25-2004, 10:20 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Any chance the previous owner installed a lower thermostat, say a 160 degree?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 06-25-2004, 10:30 PM
i put a 160 in the 91 rs that i had, i run it 2 years with it in it
all it done was overheat. i didnt know at the time that my fan
was coming on around 190. it even warped the heads,
it never run under 220, and advanced auto parts recomended it.
yeah better check it out.
Old 06-25-2004, 11:09 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
i didnt use a thermostat....
Old 06-26-2004, 11:51 AM
i got a 160 in my car and the thing runs beautifully. you just have to remember that the fans dont turn on till like 250 or something, so its gonna get hot before the ecu knows whats up. i put a manual fan switch in my car so now she runs cooler than ever...
Old 07-04-2004, 02:23 PM
trj5ar trj5ar is offline
Exclamation First things First
Always check the fan motor first!!! directly connect the fan motor to the battery.... if this does'nt work then the motor is dead and you need to replace it. If it does work then the problem lies in a relay or coolant temp sensor. which should be somewhere around the thermostat.
Old 07-04-2004, 11:27 PM
tomminajar's Avatar
tomminajar tomminajar is offline
So it doesn't come on w/ the AC ??
Get a mitchel manual or mitchel on-line or all data-
It will give you a flow chart to fix it- if you can follow it. Don't start throwing parts at it you will go broke or nuts (OR vice versa)
