Old 06-24-2004, 07:33 PM
ciVTEC94 ciVTEC94 is offline
Send a message via AIM to ciVTEC94
port polish question
can a mild port polsh be performed on an engine's exahust ports, with the header removed only, or does the entire engine need to be taken out and disassembled, my only real concern is that metal shaving backing up into the exhaust valves and doing some damage...thanks
Old 06-24-2004, 07:49 PM
Re: port polish question
oh , by the way, im performing this per the instructions on clubcivicquebec.com, on my 94 EX
Old 06-24-2004, 10:47 PM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
Re: Re: port polish question
Remove the head.......Not worth the risk.....
Old 06-24-2004, 11:03 PM
stangslayer stangslayer is offline
As long as you you only work on one port at a time and make sure that the exhaust valve is closed on that cylinder so nothing falls onto the piston. Having compressed air available to blow out all the dust would be helpful.
How much power are you expecting to pick up from polishing the port as is shown on the site you posted? If you plan on using a die grinder to enlarge the port, you should really pull the head off so a proper job can be done.
Old 06-24-2004, 11:05 PM
ok thanks, yea i was wondwering myself how much flow oculd possibly be gained from some sandpaper at the very edge of the port as in that site, wasnt sure though, never even witnessed a porting job done
Old 06-24-2004, 11:49 PM
BullShifter's Avatar
Not very much power
Do not try to port/polish your head for the first time. There's no going back, a job better off left to the pro's or going with some thing like a gude head package.
http://www.sa-motorsports.com/diyport.htm
Old 06-25-2004, 07:26 PM
thanks a lot, guys, saved me some effort for now, maybe ill give the more realistic guide a shot
