Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 06-24-2004, 07:05 PM
martinhutnik martinhutnik is offline
maxima or altima?
i heard the altima can dust a maxima, but i thought always that the max could always dust the altima. Please someone clear this up for me w/ an explanation. TY
Old 06-24-2004, 08:01 PM
TatII TatII is offline
the altima is usually a good amount quicker then the maxima. it weights a good amount less then the max and only makes 15 less hp. the atlima usually runs a high to mid 14 second 1/4 mile and hte 3.5 maxima 6 speed usually runs a 15 flat.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 06-24-2004, 08:29 PM
streetrcr45's Avatar
streetrcr45 streetrcr45 is offline
Re: maxima or altima?
i think that pretty much clears it up for you... the altima is faster..not the max
DIE TRYIN
FORGIVE BUT NEVER FORGET
Old 06-24-2004, 09:39 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
The Maxima was faster than the Altima up until 2002 when the Altima got the same V6 as the Maxima. Now it's about 0.4 seconds faster in the quarter.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 06-25-2004, 12:13 AM
ya..so now don't you have the choice of getting a 3.5 or a 2.5 liter engine in the altima?
DIE TRYIN
Old 06-25-2004, 12:54 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
a 2004 is significantly heavier but for a 2k2 or 2k3 it's only a 45 lb difference between the maxima and altima. a 3.5 se maxima is 3224lbs and the altima is 3180lbs.
also if you look on the maxima forums here you'll see that typical times for a 2k2-2k3 maxima is mid 14's with bests posted at high 14's by a few members.
if you want to search through the timeslip database you'll see a few posts like this one or this one of totally stock 3.5's running low-mid 14's; some with timeslips to prove it, some without.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 06-25-2004, 02:40 PM
cool ty
Old 06-25-2004, 02:52 PM
fugiot's Avatar
yeah, as far as speed goes...I'd take a 2002-03 max over the 02-03 altima but not over the over the 04 Max.
Don't make me ANGRY
Old 06-25-2004, 06:31 PM
AErrorist's Avatar
AErrorist AErrorist is offline
Send a message via AIM to AErrorist
Altima SE-R, coming soon
Old 06-26-2004, 12:32 PM
landyacht's Avatar
landyacht landyacht is offline
I personally think the 2000 Maxima was the best one. It had the 3.0L V6 engine still, was quite light compared to the newer ones and handled just was well. Plus i prefer that bodystyle in the Maxima.
Not to mention was about as quick, with slightly better gas mileage.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
