Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-24-2004, 04:51 PM
spedwezl's Avatar
spedwezl spedwezl is offline
Send a message via AIM to spedwezl
installing radiator Q?
hopefully this doesnt sound to dumb, but i just got a new c&r radiator and have some install quesiton. is it just simply draining the old radiator, disconnecting the hoses and swapping the new one in? or is there other stuff to look for and do. it came with one fan so i need to hook up the ac fan. any help and advice would be great....thanks
Don't fall asleep or we'll mutilate your genitals.......
Old 06-24-2004, 05:23 PM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Re: installing radiator Q?
Basically yes, but you can also run a hose through the system to flush it out, just make sure you refill it, put in all the plugs, and plug in the fans before you start the car. I replaced my radiator about a month ago, it was really quite simple.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 06-25-2004, 02:06 PM
spedwezl's Avatar
i started the install today but how do i attach the ac fan to the radiator, because it came with one already. should i just go to like pep boys of somthin to get a mountain braket for it or do i need to talk to the place where i bought the radiator?
Old 06-25-2004, 05:46 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
the radiator has two fans on it. A/C and radiator fan. are you saying there's only room for one fan?
Old 06-25-2004, 06:51 PM
spedwezl's Avatar
no im saying it has room for 2 fans, but only 1 fan came with it....is that 1 fan good enough? or do i need to put on a 2nd fan?
Old 06-25-2004, 07:54 PM
Didn't you keep the fans from your old radiator? My radiator didn't come with any fans, you just use the old ones. Even if the radiator is bad, unless you crashed and messed up the fans, then you can use the old ones. In your case, use the new fan you got, and use the old one that fits the other space since they are different sizes.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 06-26-2004, 11:32 AM
spedwezl's Avatar
Re: Re: installing radiator Q?
i did keep the old fans from my old radiator. but on my new radiator there is no way to connect another fan to it. do they sell mounting kits at like a pepboys? or how do i go about hooking the fan on there.
Old 06-26-2004, 06:47 PM
rubix777's Avatar
you'll have to do some fabrication. When I bought my replacement radiator, it had room for both fans, so I just took the old fans off the broken radiator and put them on the new radiator.
Old 06-26-2004, 07:06 PM
Same here, mine has OEM mounting points.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 06-27-2004, 10:24 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
If I remember correctly, the C&R radiators comes with that single fan to replace the two stock fans. To be positive, I would send them an email to confirm this fact. But for the while, I think you should be okay with one fan as long as you don't overwork your engine and keep an eye on the engine temp.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 06-28-2004, 03:35 PM
spedwezl's Avatar
thanks for all the help. the one fan did turn out to be enough and pulled in more air then my 2 stock fan which was kick ass. so thanks again everyone.....
