Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-24-2004, 04:02 PM
integratool666 integratool666 is offline
rpms
just wondering what the difference in redline is between the gsr and ls integra are - and why are they different?
Old 06-24-2004, 06:33 PM
tsugsr tsugsr is offline
Re: rpms
the LS's redline is 6,800 while the GSR's is 8,200. the redline is different because of higher compression motor, vtec, and a bunch of other little things.
Old 06-26-2004, 11:03 AM
Re: rpms
ohhhhhhhh - ok - makes sence
Old 06-26-2004, 07:08 PM
98-integra 98-integra is offline
Re: rpms
the Ls also has a lower rod ratio which is like 1.54 which means at high rpms the ls would start side loading
Old 06-26-2004, 10:57 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
Re: rpms
what if u get the block balanced and blueprinted? and then get the bottom maincaps from a gsr. would that help to keep the block together?
Old 06-27-2004, 12:27 AM
integralover's Avatar
integralover integralover is offline
Re: Re: rpms
what do you mean by side loading? i was a damn idiot and bought this racing chip(so to say) off ebay and installed it. it gave me some noticable gains and set my rev limiter to 9,200 rpm's. yeah, that high. i was the dumbass that i was and would take it to 8k or sometimes 8,500 rpm's. yeah real stupid of me. well, i spun a bearing in that engine and that is why i know have to b20. i did take out the racing chip. but can reving the engine that high cause that to happen?
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 06-27-2004, 12:24 PM
Re: rpms
side loading is when you dont have a good rod ratio like the ls (1.54) at high rpms the piston dont come down in the center they come down off to one side
Old 06-28-2004, 12:37 AM
ah i see. thnx for clearifing that for me.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 06-28-2004, 04:04 AM
AMinHtY AMinHtY is offline
Re: rpms
i have a prob with my 93 Ls its an auto with a powerchip dotn know wat one. but the revs go to 7000 but its really slow. Its sounds really gutsy but its hell slow. My friend says it my transmission and i polli need to replace the clutch pads cause the power isnt getting to the wheels. i dont know what the hell is going on ive never heard of changing pads in an auto befor, help
Old 06-28-2004, 12:24 PM
~ls/vtec~'s Avatar
Re: rpms
try the torque converter no the clutch pads
Old 06-28-2004, 10:47 PM
i'd like to see him replace the clutch pads. i had a friend who had a 93 ls that was auto. she hated her car. then she drove mine and damn she could work a stick
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 06-29-2004, 05:11 AM
Re: rpms
hey integra lover do u have any more pics of ur car
i wanna check it out
Old 06-29-2004, 12:12 PM
Re: rpms
so how can you prevent side loading - do you have get new rods, pistons and cranks - how much power could you get if you changed those two things - and maybe the camshafts too?
Old 06-29-2004, 01:40 PM
Re: rpms
to prevent side loading you need to make sure you have the proper rod/stroke ratio, which is done by proper piston/rod/ and crank selection. and as for how much power...that all depends on which parts you go with for where you want your power band to be.
