Old 06-24-2004, 02:12 PM
dwk617 dwk617 is offline
Send a message via AIM to dwk617
Angry gas and trunk release problems
I had just put in a new trunk and gas tank switch thinking this would solve the problem but i still can't get neither to work i tried changing the fuse. has anyone else had this problem let me know.
Old 06-25-2004, 02:30 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Can you hear a relay click when you push the button? If not I would check replace the relay. I believe it is located behind the glovebox. This is where the click comes from when I pop the trunk or fuel door in my girlfriend's '99 Intrigue.
Old 06-25-2004, 09:05 AM
Re: gas and trunk release problems
yeah i here the relay clicking when i hit the buttons but nothing happens do you think that something has come lose somewhere or the relay may have a short in it
Old 06-25-2004, 04:57 PM
Ruley73's Avatar
Is your gas cap cover seized? spray some WD-40 or something on the spring and see if this helps. On my GF's car her trunk will release but does not pop-up by itself. Does your trunk lid pop up by itself when you open it or do you need to lift it yourself? I think my GF's trunk lift supports might be worn out. If this doesn't help I don't know what to tell you.
Old 10-22-2004, 12:13 PM
iceman2 iceman2 is offline
I am having the same problem with my 1998 88, I can hear the click in the glove box, the trunk releases about 1 in every 30 or so tries.
Old 02-01-2006, 03:54 PM
JimB442 JimB442 is offline
My dad has an Intrigue and the power trunk release quit. In my 99 Mazda 626 there is a disable switch inside the trunk.....I guess to prevent or help prevent thieves from entering the trunk even if they break into the car. Anybody know if the Intrigue has such a switch. I haven't had a chance to look at the car yet myself.
