280CE vacuum diagram
My 1985 280CE has a slow throttle response when cold. Works just great at operating temperature.
Can anyone help? Does anyone have a vacuum diagram for this car? It is a grey car with only 665 built. I can not find a motor manual for it. Thanks Ernie |
Grey market cars are a losing proposition. The vacuum diagram for your car should be really simple if it really is a CE, meaning coupe, fuel injected. E is for einspritzer, German for injection. The only vacuum for the engine will be for whatever emissions mods were made by who knows and some simpler subsystems. If I were you, I'd check the fuel pump relay, the cold start injector, the air flow meter and the electro-hydraulic actuator. Also check the idle air slide valve. These are all famous for causing or mimicking the situation you describe.
If you don't have the toll money, can you still get to the light at the end of the tunnel? |
