Old 06-24-2004, 02:28 PM
angel511420 angel511420 is offline
Send a message via AIM to angel511420 Send a message via Yahoo to angel511420
Angry air conditioning problems
i cant get my air conditioning or vent to work. when i turn the knob all the way to cold and put the air or vent on its all heat. i dont know what the problem is so if anyone can help me it would be great.
Old 06-24-2004, 02:57 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
compressor is not kicking on. That could be for many reasons, the most common is that their is not enough r-134a to set off the pressure switch. The next common thing is that the compressor clutch is not working. unplug the harness to the high pressure switch and with the car running and the AC on use a wire to short the termanials in the harness (Not the pressure switch) if the compressor kicks on then you know the clutch works. Don't let it run for long if it does kick on. That test will tell you one of two things, 1 you don't have enought pressure in your AC system, 2. You have bad pressure switches. More than likly you just need a recharge.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
